Post your g-meters
Old 10-31-2016, 12:00 PM
hsmith
hsmith's Avatar
I am very impressed with my GTS lateral grip. This was at Lime Rock on MPSC2's
Old 10-31-2016, 04:27 PM
Churchill
Churchill's Avatar
That is impressive.
Old 10-31-2016, 04:48 PM
Roosell
Roosell's Avatar
Seriously. 1.7 seems like just below being t-boned by a Hyundia. I haven't been above 1.1
Old 10-31-2016, 07:28 PM
GTOWN83
GTOWN83's Avatar
WOW!, Impressive numbers. Evidently, I'm driving my Pcar like a grandpa......Oh yea, I am one.
Old 11-01-2016, 01:55 PM
Fred2
Fred2's Avatar
Published tests show a skid pad value of 1.04
Is the G meter accurate?
or
How do you explain the high numbers?
Old 11-01-2016, 02:11 PM
amre
amre's Avatar
or
I'm not sure if this is correct, but I believe the lateral grip test is performed on a circular track and the car is accelerated slowly till it starts to lose grip or deviate from its path. At that point, the max G-Force is recorded.
The G-Force meter that's on the car can record instantaneous measures so you don't have to be constantly accelerating or going at speeds to get a high number on our installed meters. You can just take one sharp 90-deg turn at 25mph and record a number above 1.0 easily. It's not the same as constant grip at speed.
Old 11-01-2016, 02:13 PM
subshooter
subshooter's Avatar
Received 2,263 Likes on 1,039 Posts
or
A couple of reasons.
1. Different tires than test set up.
2. Different tire/track temperatures than test set up
3. They actually hit something and caused a high g force to be recorded.
4. Spin etc or jolt when sliding across uneven surfaces or surfaces that have an abrupt change in friction coefficients.
5. Hills/angles (not flat)
The skid pad values are determined by turning the car at constant radius on a flat surface while increasing speed until the outer most tires begin to slip. That speed is then placed into a formula to calculate the lateral g force. Anything that deviates from that methodology will produce different results.
I believe that the G force meter in our cars is an instantaneous measurement and not based on the above methodology which will produce higher values.
Old 11-01-2016, 02:16 PM
mwar99
mwar99's Avatar
Downhill right-hander onto the front straight at LRP can carry a lot of grip, as evidence by this G meter post. I've seen someone with over 1.8 before on a GT3 with a similar situation providing extra physical grip.
Old 11-01-2016, 03:09 PM
Churchill
Churchill's Avatar
This is key. Even a slightly banked turn on the track will allow a good deal more lateral grip than a non-banked turn.
Old 11-01-2016, 09:50 PM
Karl911
Karl911's Avatar
that 1.73 g , you were definitively sliding in a sideways drift !!
Old 11-02-2016, 01:56 AM
RonD
RonD's Avatar
This is from a Laguna track day. C2S with PDCC on MPS Cup2.
Old 11-02-2016, 07:57 AM
budrichard
budrichard's Avatar
+1
Once you exceed the friction force keeping your vehicle from sliding in a corner, the G Force increases dramatically and is not related to any maximum G Force representing constant tire grip.-Richard
Old 11-02-2016, 05:17 PM
hsmith
hsmith's Avatar
Not sliding/drifting. I assume it was at the downhill that i achieved that figure.
Old 11-02-2016, 05:56 PM
Grunty
Grunty's Avatar
In a driving school I did, the gmeter would show a sustained 2.5 - 2.7 for the majority of a particular long turn. However, there would be a spike each time that was much higher. What causes this? I assume it's a false reading. these were formula cars which is why the readings are higher.
Old 11-02-2016, 06:01 PM
subshooter
subshooter's Avatar
Originally Posted by budrichard
+1
Sorry but you guys are mistaken on this point. The coefficient for static friction is > than the coefficient for kinetic friction.
In other words, once your tires start to slide, the g forces will decrease. I'd be happy to go through all the math and newtons equations at the risk of being a nerd and boring everyone.
He either hit something or it was on a steep decline and turn.
Quick Reply: Post your g-meters
