Quick Sports Chrono Help
Does any one know if the sports chrono gauge is supposed to light up like normal gauges at night? Mine is dark (no light) except for the digital clock shows.
Just wanted to see if this was normal.
Mine used to light up around the ring until it was replaced. Now not only does it fail to light up, the analog clock always shows 12 noon.
I've been meaning to get that fixed...
Does that sound like what you are seeing.
Exactly Fasttr, what I see. Mainly a reflection from the digital clock, but remainer of gauge is pretty dark. Figured it would light up, but maybe it's normal.
Just got back from a night drive and was thinking about your post. The SC gauge appears to have a very slight illumination of the outer ring.... but its so slight I had to really look at it to tell is was not just a reflection of the digital clock display in the gauge. Certainly the numbers and the arms in the SC gauge are not illuminated at all. So other then the digital clock numbers, the SC gauge is pretty dark overall.
Interestingly, if you de-select time - chrono, not only does the digital clock turn off and the sweep hand stop, but the whole display goes dark. Strange.
Just went and played with it, and it's definitely lit around the perimeter. Not just a reflection from the digital display.
