pdk transmission replacement ! advice pleasee...
The pdk transmission on my 2012 991 is being replaced by the dealer....I would appreciate ANY advice from any of you ladies and gentlemen as to any thing I should look for or be careful about after I take the car back.........Thanks
Sir Thomas Lord of All Mets Fans
T
To the original poster, I don't speak for everyone but it's a pet peeve of mine when someone comes on here looking for advice "ASAP" on what appears to be a very serious issue with an owner's vehicle, and then ditches for a while.
When you're asking others for advice, you should probably give them the respect of acknowledging their questions / comments.
Anyone with me on this?
I have made a habit of not responding to people that are new thread starters with very few posts until I am sure they have some skin in the game. Too many post and ditch for my time to be wasted.
to the critics : Did it ever cross your genius minds that there might be a reason why I was brief in my thread and not responding !!!!!??????
to others : thanks for your inputs and I will post the whole story when it is appropriate to do so....thanks again
Transmission developed a selector shaft seal leak and the factory said "replace it" and shipped a new transmission over. Took a couple of weeks to arrive.
As replacements go replacing the transmission is not that big a deal.
My advice is to when you go to to pick up the car believe you will have to leave it.
Give the car a mini-"used" car check out. Give the car a visual inspection. Open the engine compartment and check everything looks ok.
In the car turn on the key and verify all warning lights come on then go off when you start the engine.
Let the engine idle some and listen to the engine to make sure it sounds ok, idles ok. Listen to the PDK to make sure it doesn't make any odd noises.
After a bit shift the PDK from park to neutral to drive to reverse and so on and that it "shifts" ok. You are looking for, listening for any signs the linkage is not working right.
After more idling then take the car out on a road test. Drive the car normally while the engine (and PDK) warm up. You want to give the PDK a work out. Stop and go. Accelerating from a dead stop. Do a K-turn or two to make sure the PDK can handle rapid changes in direction with no drama. Steady speed cruising. If possible then on the highway test the kickdown feature. Try to use the manual shift feature to make sure this works ok.
In brief just make sure that the car, the engine, and the PDK all work with no symptoms or signs of any trouble.
If you find a problem get the car back to the dealer and leave it to have the problem addressed. If you take the car you are signaling to the dealer you will accept sub-par results and this makes getting things taken care of right harder.
After you accept the car remember the replacement PDK is new so if there is a break in period for the PDK adhere to it. And keep your eyes and ears open to any signs of any problems from the "new" PDK while the engine is running and on the road but also before you get in the car check for any fluid leak sign and check the garage floor for any leak sign. While it is new even new ones can develop a problem. The odds are very slim the replacement will act up -- my Turbo's replacement 6-speed has been a dream of a transmission -- but you want to be aware of the possibility.
Be sure you come back and tell us the "rest of the story"!
When it's appropriate? Why'd you start this thread? What could possibly be inappropriate about answering all the questions everyone was asking?
I generally refrain from calling people out because there's really no point and we are all adults, but I smell Bull Crap here.
