Rear Ended! :(
See if your local (what ever is most local to you) Porsche Collision Center has the fancy Porsche spec chassis alignment equipment - not wheel alignment, chassis alignment. Make sure they measure your chassis alignment and verify it is within spec.
There's a thread somewhere on RL where a guy took a light hit in the rear end. Unfortunately it was where the crumple bumper connects to the chassis and the result was a direct hit to the chassis itself that caused the chassis to bend. Something body work people would never pick up. He had to have the motor removed, they looked up under the car where the motor box chassis meets the unibody and found the bent components. All fixed good as new, but the body shop folks would have never caught this.
Received 1,648 Likes
