Brake fluid flush with the Power Bleeder
I've used Motive bleeders and they do work well, but I personally prefer the much simpler Power Probe BA05. You use it to lightly pressurize the master reservoir itself, one less thing to clean and store. You do need an air compressor with the ability to control the pressure though...
It also wastes much less fluid. Not a big deal if you are using most normal fluids, but I like to run Castrol SRF and at $60+ a pint, I don't like to waste any nor would I want to re-bottle it after putting it in the Motive.
The only disadvantage is that if you want to flush the entire system instead of just bleeding, you need to depressurize, remove the cap, and top of the system once or twice during the process.
About $30.
As for wheel hangers, no need to make your own unless you really want to... M14x1.5 pilot pins are readily available for under $10. Absolute must IMHO if you do your own wheel or brake work on a Porsche.
About $30.
Thanks for the tip on the wheel pilots, I'll look them up.
We carry all of the Motive Bleeders and Speed Bleeders as well.
https://www.paragon-products.com/Sea...motive+bleeder
https://www.paragon-products.com/Sea...=speed+bleeder
http://www.paragon-products.com/Sear...Search=sb_1010
I'll update our listing. Pretty much all Porsche models from the 964 on will use this 10mm bleeder.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
