Brake fluid flush with the Power Bleeder
Rather than spend the $200 or more that the dealer charges for a brake fluid flush, I bought the Motive Power Bleeder and decided to do it myself. The bleeder worked great, used genuine Porsche DOT4 fluid, and the brake system is good for another 2 years.
Couple of notes: get the bleeder set up with a pint or so of new fluid in it, and prime the hose so that you get fluid into the reservoir sooner. Some say pump it up to 15 psi, but I didn't go past 7 psi and had plenty of flow out of the bleeders.
Simple job. The hardest part is getting the fat wheels back on, so I need to go get some 14mm shoulder bolts and make up a couple of pilot studs for next time.
The Motive Power Bleeder is a great product! Glad to hear it worked for you. Do you know off hand what the part number is for the master cylinder adapter you used? I have a couple, but they are for domestic cars. Thanks.
Great job. Great to see DIYers in action.
I've used Motive bleeders and they do work well, but I personally prefer the much simpler Power Probe BA05. You use it to lightly pressurize the master reservoir itself, one less thing to clean and store. You do need an air compressor with the ability to control the pressure though...
It also wastes much less fluid. Not a big deal if you are using most normal fluids, but I like to run Castrol SRF and at $60+ a pint, I don't like to waste any nor would I want to re-bottle it after putting it in the Motive.
The only disadvantage is that if you want to flush the entire system instead of just bleeding, you need to depressurize, remove the cap, and top of the system once or twice during the process.
About $30.
As for wheel hangers, no need to make your own unless you really want to... M14x1.5 pilot pins are readily available for under $10. Absolute must IMHO if you do your own wheel or brake work on a Porsche.
About $30.
Nice work, OP, it's really satisfying to do your own maintenance. And with the money you save you can buy some more tools!
The Motive website indicates the Black label European for Porsche is 1109. Other sites indicate 1100, I am not sure why there is a difference. Anyone know which to buy?
They both will fit. But the 0109 Black Label has an aluminum cap and swivel fitting which makes attaching and removing far easier. This is the the one to get.
Awesome write up. I use the Motive - Black Label version, it has an anodized aluminum cap for longevity . One thing, the torque specs on the bleeder screws are 9-12ft-lb. Start with 9ft-lb to be safe.
https://www.ecstuning.com/b-motive-p...el/motive0109/
Thank you, doing Pagids this weekend, so since they shipped me two 500ml Motul 600 for $1 each, flush is happening as well . I am going to order the 0109.
Wow! Motul for $1!!!! I gotta know where to get that deal. I need to order another set of Pagids as well. ($$$)
http://www.paragon-products.com/category-s/662.htm
Free freight too!
We carry all of the Motive Bleeders and Speed Bleeders as well.
https://www.paragon-products.com/Sea...motive+bleeder
https://www.paragon-products.com/Sea...=speed+bleeder
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
