Another tire question...
Sorry if this has been covered already. I have a 2012 991 Cabrio (base). Need to replace my rear tires. I have Carerra classic wheels 20". I want to go from the stock 295's to 305's. From some of the other posts, it appears I will have no proiblem getting them installed?
991 mavens can you chime in? Thanks for the help.
Received 5,402 Likes
Jeff, make sure you can obtain the 305s. They were in very short supply last year. Michelin and Pirelli, both.
From a performance standpoint, i think you'd need to be a highly skilled driver, wringing out the car, to really notice.
305s;
Cost more
Weight more
Harder to source
Less selection
There is no significant benefit other than some people feel that the 305 looks better. Problem is the Michelins are extremely hard to find so have to settle for 295s if want Michelin which I did.
For the everyday 991 driver, it's more about appearance. The 305 looks a little wider from the rear.
305s;
Cost more
Weight more
Harder to source
Less selection
305s;
Cost more
Weight more
Harder to source
Less selection
Example, my M5's rear wheels are 10" wide using 295. 991 equipped with 11" are using 295". GT3 puts 305 on 12" wheels while non-GT cars run 305 on 11.5".
C2 Rear Setup
11Jx20 ET70 (295)
11.5Jx20 ET68 (305)
C4 Rear Setup
11Jx19 ET67 (295)
11.5Jx19 ET50 (305)
I am coming up on replacing my PZeros and searched the forums on the MPSS. I found these tires but they are not cheap and maybe overkill for me not using the car on the track.
Question: Do they make the N rated MPSS tires or only in the Cup version?
Michelin Pilot Sport Cup 2Not Yet Rated | Reviews (10)
Click to Compare
MICHELIN
PILOT SPORT CUP 2
Streetable Track & Competition
Front: 245/35ZR20 (91Y)
N0 Porsche
Sidewall Style: Blackwall
UTQG: 180 AA A
Qty:Per Tire:
2
$472.00
Availability: In Stock
Can be delivered Thu, 05/19 to 33304 for $19.22 per tire.
Rear: 305/30ZR20 (103Y) XL
N0 Porsche
UTQG: 180 AA A
Qty:Per Tire:
2
$469.00
Can be delivered Thu, 05/19 to 33304 for $34.18 per tire.
Click to Compare
MICHELIN
PILOT SPORT CUP 2
N0 Porsche
UTQG: 180 AA A
Qty:Per Tire:
2
$472.00
N0 Porsche
UTQG: 180 AA A
Qty:Per Tire:
2
$469.00
I am coming up on replacing my PZeros and searched the forums on the MPSS. I found these tires but they are not cheap and maybe overkill for me not using the car on the track. Question: Do they make the N rated MPSS tires or only in the Cup version? Michelin Pilot Sport Cup 2Not Yet Rated | Reviews (10) Click to Compare MICHELIN PILOT SPORT CUP 2 Streetable Track & Competition Front: 245/35ZR20 (91Y) N0 Porsche Sidewall Style: Blackwall UTQG: 180 AA A Qty:Per Tire: 2 $472.00 Availability: In Stock Can be delivered Thu, 05/19 to 33304 for $19.22 per tire. Rear: 305/30ZR20 (103Y) XL N0 Porsche Sidewall Style: Blackwall UTQG: 180 AA A Qty:Per Tire: 2 $469.00 Availability: In Stock Can be delivered Thu, 05/19 to 33304 for $34.18 per tire.
Your looking at S vs base wheels. All 991S' (rwd or awd) came with 8.5"x20 front and 11"x20 wheels with different offsets in the rear as you point out. They put 295s on the NB and 305 rear tires on the WB cars. Just saying. The GTS and some special wheels (Fuchs and Sport Techno) had even wider front (9") and rear (11.5") wheels. These wheels always have 305s even if on a NB.
