PCM Tech on 2012 vs 2013+?
Narrowing my 991 search. Found a 2012 C2S CPO that I'm going to look at tomorrow.
Is there any difference in the technology capabilities of the PCM on the first year vs 2013 and up?
Any other major differences or refreshes mid-cycle before the 991.2?
from my experience from 2012-2016 other than maybe software updates, hardware remained unchanged. I own a 2012 991 and owned a 2014 CaymanS, which has the same PCM.
Good to know, thanks. How is the iPhone interface with the PCM? Can you control your iPhone music directly from the PCM or do you have to do it from the phone. My 2016 BMW M235i's iDrive is pretty intuitive and integrates my iPhone pretty well via Bluetooth and tethered. Hoping I'm not giving up too much in this switch (from a PCM perspective that is!).
I believe that the early 991s (2012.5) had a slightly different version of the PCM hardware.
Somewhere in around October 2012 build date cars they switched to the PCM with "Jukebox" hard drive music storage function.
I have Dec '11 build date 991S and it definitely does not have the jukebox function.
What are my best options for music? Just load up a USB stick and leave it plugged in? Burn a few DVDs with AAC/MP3 files and load them into 6 disc changer?
Can I add the jukebox?
I have an early 2013 build and no throttle blip whatsoever. I wasn't aware I might have a jukebox either, gotta go look now - been using a 64 gig USB key that's more than enough for music.
