Weird Coolant issue 991.2
Same problem here on my 991.2 C4S Temp above 120C and warning message Refill Coolant Immediately Stop Driving. Coolant level is fine it happened for the fourth time I gave in the car to the dealer and might get a refund if the problem doesn't get solved.
Vivek
Received 2,267 Likes
+1 on the bubble. Mine occurred at 2000 miles and freaked me out. (981 BS).
Dealer said that the "fast fill" procedure for the coolant at the factory sometimes leaves a bubble in the system. They bleed it and added more coolant. Problems solved and 25k miles later, no issue.
I'm not sure why it takes so many miles to reveal itself though.
Mark
Mark
Hi,
I have about 1200 miles on my 991.2 C4S and had a strange issue last night and this morning. Started the car up last night and drove a short distance and got a low coolant warning. Temps all looked fine, drove a few more minutes and then suddenly I got a red light to pull over and replace coolant immediately and the needle had suddenly shot up to 250°F (pegged the needle). I pulled out at a gas station to go see what coolant they may have, didn't have any that matched what was recommended (what should you do in this case, what are alternatives?).
Got back to the car and checked the coolant and it was fine. Started the car up and the warnings were gone, drove the remaining 10 minutes home and no issues or warning.
This morning had almost a repeat, but this time as it pegged to 250 I was about to pull out after I found a spot (was driving to the dealer), then it just suddenly all reset and no issues and the temperature was showing 194°F again as usual. No issues and all alerts gone and no problems driving for the next 45 minutes.
Anyone seen something like this before? Taking it to the dealer on Monday morning to have the sensor checked out, seems like something is faulty and just giving bad codes.
Thanks,
Vivek
Thanks,
Vivek
I have had this one!! Exactly the same.... So I won't repeat your story above, but I can tell you what mine was from. Definitely low coolant (was checked as per pre-delivery).... and only two weeks old. Checked level and indeed low, called dealer, checked the next day and when the dealer tested the system (pressure and sensor) they found residue of a leak. When the removed the sensor in the coolant reservoir they found a 'hair line' crack which under pressure 'spirited drive' it had caused the leak. NOTE I did not have any signs of smell, leaks on the floor, or any other noticeable marks. I'm fastidious with my cars. The dealer had never seen it before but ordered a new coolant reservoir and I have had NO issues since its replacement. They also sent the old reservoir back to Germany as this is the first time occurring in Australia.
Let me know how you go.
JJ
On a related issue, when should the coolant be replaced? There's no maintenance information on replacement that I could find and nothing lasts forever.
Got the coolant red warning STOP driving immediately today. Temperature gauge shot up to 250 immediately. I was driving my 991.2 C4S, has about 1600 miles, for about 5 minutes on a highway. When warning came on I pull over to the shoulder. As soon as the car came to a stop (I didn't have to shut off the engine) the warning light went off and the temperature gauge went back down to 200. I waited a minute and then drove off. I drove for another 25 miles without a problem.
Rennlist is great, I was aware of this potential issue and didn't have a panic attack.
Called the dealer, taking the car in Saturday.
Glad this worked out for you! My first instance of having this definitely turned out to be a leak so do check to see if your coolant level is okay, if not top up with distilled water. The reason the light went away was it built up enough volume as things warmed up, so that it functioned. The second time this happened was a bubble after they had done the fill that caused the sensor to think there was no coolant, they bled it off and filled and since then there has been no problem.
I've had no more problems and I'm over 4300 (s)miles now.
Good luck!
Vivek
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
If you do check the coolant level, do it cold as they system is so large (something like 12lts) the difference between min and max on the float coolant indicator is not much. Having said that when I check mine the next day after the warning ie in the morning, the bulb was leaning against min and I couldn't even see coolant. Dealer was fantastic.
I haven't had any issues since they fixed it
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Got the car back from dealer today. They "reflashed DME" as part of WG30 Campaign. I was told it was a software issue that caused the red warning.
I drove about 15 minutes from dealer. Guess what? Same red warning came on. I pulled over and shut car off. Turned it back on warning went away.
Called the dealer, of course the service department was now closed. Stay tuned. I guess I'm going back to the dealer for another look
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Called the dealer, of course the service department was now closed. Stay tuned. I guess I'm going back to the dealer for another look![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Vivek
