New Radar/Laser System Installed
Soooooo....I never really got the point of these. I mean if the laser is already pointing at you then isn't it too late already?
I had one of the dash mounted ones for a while but it used to go off all the time and I was constantly tensed up either waiting for something to happen or looking for whatever made it go off.
I gave up with it and enjoyed driving a whole lot more.
My 2c...........
My 2c...........
Laser versus laser jammer, no.
Platinum Sponsor
Also, they have to prove that you're running jammers, and if you use them properly(turn jamming off after slowing to the speed limit) they will likely never know.
Now I need to test it.
What Laser Gun can I buy on E Bay? With out spending a fortune.
See how the installer (sloppily) made those half moon cut on the trim. That is to access the "S" menu button and on the left there is a blank button. The display face has 5 blank buttons. 4 of those are lost with the ash-tray installation.
I think the display is perfect where it is. It is easy to see, easy to reach. The menu, mute function and volume are a piece of cake.
Platinum Sponsor
I had considered the ash-tray mount location and although you can make it fit does not look so great in there and you lose some junctions.
Also, 4 of the blank buttons are not accessible.
Platinum Sponsor
The covering of the 4/5 blank buttons I can understand. I don't have a lot of hands-on with the Stinger system — what are the blank buttons used for?
2. The functions of the 5 blank buttons are.
Top right=volume up
Lower right= volume down
Upper left=return to pilot screen from anywhere within the menu.
Lower left= a K and Ka band graph.
Center left is the one accessible in with the ash-tray install. Turns K band on and off. K band comes back on with reboot of system unless you have it disable from within the menu.
Hey Nick,
While I have you attention here. What is decent LIDAR Gun to pick up on ebay.
My thoughts on this are that installers should have one. I don't know if you do or not and perhaps my logic is flawed, but testing of these devices would be near the top of my priority list if I was in that business.
Platinum Sponsor
Hey Nick,
Here's one that we use all the time:
You don't need a gun unless you want to spend several thousand dollars testing effectiveness — I would leave that to the manufacturers and organizations like RALETC. For an installation facility or a consumer, all you need is a low power tester.
Here's one that we use all the time: Laser tester
Platinum Sponsor
Nick, wouldn't this only test that the jammers work? It would not test if the jammers are effective (ie, they may work fine, but not effective out on the road versus off axis hits or from a cop shooting from a bridge). For that he needs to test it in real world environment, out on the road.
The technician/integrators job is to make sure the system functions properly and the sensors/jammers are positioned correctly, everything else is on the product manufacturer IMO.
...........This is an install issue with me. I am taking pictures right now. I will be back on forum for thoughts on this in a while. I will be going back to Signature Audio now to move at least (2) of my LIDAR receivers. The two in the back are both my and Signature Audios mistakes.
Later
