Dimensions of Rear Window (Targa)?
Looking for approximate dimensions of a 991.1 rear window on a Targa. Going to pick up a sunshade on eBay to protect the little one in the rear seat. Anyone with a tape measure handy? Looking for length and width. TIA
Torque.... are you still in need of this info? and if so, exactly what do you want measured, just the width and height if the flat part of the window.... excluding the wrap on both sides?
I took these before going to the office. Let me know if you need more precise measurements. I may be able to get them later today. I hope this helps.
Note the tape is hanging out a bit on the left.
The start of the tape on the left is where 39” is. If you only want the width inside the curves, taking out 2.5” on each side, you have 34”.
Note this is on the outside edges.
Note the antenna and keep in mind to take a bit off since I measured on the outside.
