Thanks RL! iPhone and Escort hard-wired into the FG Targa
#32
Used a metra plastic pry tool.
The wires tucked in very easily. Some areas, such as the lower-right corner, need a bit of force to get in.
Wires all tucked in and completely hidden - fed right into the glovebox.
I started running the wire from the top, ran it through the bottom, and then fed the plug from a hole in the lower-right area of the glovebox.
The wire snakes around from the entry point through the slot on the top. Plugged straight into the 12V adapter, which avoids using an add-a fuse and running from the fuse box.
