GTS mesh grill question
#46
I am about to order these but not sure if part numbers are correct. Followed the questions indicating is GTS, that should cover it right?
http://www.rennline.com/basket.asp
#47
Another question - Tony, why do you feel these grilles are closest to OEM GT3 ? Any general thoughts on quality etc. are also appreciated. P.S. I should have bought your 50th. It was perfect. Oh well
TChap - Did you order and install ? Thoughts ?
Cheers
#50
You all are killing me....the supposed discount code is not jumping out in this thread.
I guess i'll have to use my search skills...
#51
#52
#55
It could be worse! Good deal.
Post up a pic once you receive.
It would be appreciated!
#57
Some pics of my Zunsport front air intake grill install. Took longer then I had expected. Approx. 45 min. Mostly due to deficiencies in the accuracy of the product. Namely the tabs/hooks that secure the grills. There is also a problem with the outer left and right grill insert. The medial portion (inside) part of it sticks out a little (mostly because of the horizontal black bar in the air intake cavity) causing a gap. Previous products had two separate pieces for this intake (Turbo model). A better design might be a grill for above and one below the horizontal black bar. Not sure why the pics are rotated on some. Sorry.
#58
Overall, are you satisfied?
#59
They didn't mention anything about duties or taxes. We'ill see when i pick them up today when i arrive in MN.
#60
Ease of Installation 7/10
Quality of Product 10/10
Product size/accuracy for opening of air intake 6/10 (They may need to tweak the design a little for a more seamless fit with no gaps).
