Buying a 991 - RWD or AWD?
#47
I disagree. I have the bigger a## GTS lol Hey, is this like arguing who the best guitar player is lol All in fun (: Actually the specs of the Carrera 4S AWD and GTS are the same in width in the bodies. But the GTS runs a 1/2 wider rim front and back with the same rubber as the 4S. The GTS gives you the exact hip width in the back as the 4s, wider rims, upgraded power kit and other options. Bargin if a person tries to add that stuff later.
#48
I feel like the bigger booty of the AWD/GTS on the 997.2 was a bigger improvement over the standard booty than it is on the 991. I think the top of the hips on the 997.2s was noticeably flatter on top than the standard, vs in 991 even though it comes out wider, which is good, the top is almost exactly the same and the difference in the curvature comes in at the lower part of the booty where it's already started to curve downward, it just does so at a slower rate. Maybe I spend too much time staring at booty.
#49
