Awesome, thanks for link - I've been wondering about this.
My phone book is rather large (several hundred entries) and going through the alphabet isn't convenient for people toward the end of the alphabet. So if I wanted to call John Doe's cell phone, what would be the string of commands you would issue?
I don't really use it... but "Call John Doe" will get it done.
When I go on long trips I use this windshield mount. I've had this for years and have used it in multiple cars Other wise it's just on the seat or in the door pocket. I was surprised how strong the arm is which allows you to touch and tap your way through the screens if need be with little movement.
I ordered the Scosche Magic Mount, but it didn't work well the the iPhone 6S Plus.
Wow, that's interesting. I have a 6S (smaller phone) and it is rock solid. Wouldn't have thought the extra size would make that much difference. Did you use the large steel plate on your phone?
I went off-roading Saturday in my Wrangler -- aired down, sway bars disconnected, bouncing over a lot of rock, up, down, sideways at crazy angles. I marveled that the only time the phone moved was when I was reaching for the radio volume and hit it with my hand.
I did it myself and would rate it a 3 on a scale of 1-10 for difficulty. It comes with great instructions. The only challenge is getting the cables through the firewall, but the whole thing took me maybe an hour to complete.
I am assuming you have to take your phone case off every time right?
Does this prevent the driver's cup holder from being used?
Yes it does. That's why I did not get it.
I did, however, get the sunglasses holder and it's the bomb. So nice that I am going to have Vlad make me one for the driver's side so I can store a 2nd pair.
For my iPhone 6+, I use the adhesive mount Scosch (spelling?). No issues.
Well clearly he has more than one assistant and therefore it is likely that there are more than two ***** involved. Possibly four. Maximum of 6 in the 911 though. If it's only two *****, he's in a Boxster and clearly insufficiently elitist.
