Clear tail light
Removal is a 5 minute job per side.
1) Raise the spoiler to be fully extended
2) You will see a plastic cover that is almost square on the deck below the spoiler. Pull the cover straight up and off.
3) Remove the two small torx bolts. There are three in total only the two smaller are to be removed.
4) Carefully slide the tail light towards you and when it clears the body remove the wire connection with a small screw driver.
To reinstall, reverse the above.
