Need some advice on sport techno
I would like to put a set of sport techno wheel off a 2012 991 c2 on a
2014 991 4s.
The ET is different by 20mm, I going to need spacers but don't now how big.
I there someone that has run into this problem?
HELP!!!
2014 991 4s.
HELP!!!
Correct, will need at least 20-25mm spacers...
...Elephant Racing is only place I'm aware of that offers something that large.
Will need longer bolts, also.
Received 5,410 Likes
That's a huge spacer. IMO, buy the right wheels with the proper offset. Save the unsprung weight, too.
Yes buying the wheels with the proper upset is probably the way to go but Porsche seems to think they are worth $7000
Does anyone know of anybody out there that has run into this problem and overcome it problem with spacers is what you buy and you can't send them back
This^^^^. And be patient. The wide body ST wheels can be found if you just wait a bit. They come up on EBay more frequently than you might guess. Even the 50th anniversary wheels (which are identical to the ST wide body size/offset) come up occasionally. Both are the best for the 991 wide body if you ask me.
What wheels are on your car now?
Someone might be interested in a swap.
offsets...
Sport Techno wheels
Front - 9 x 20 ET51 - 245/35 ZR 20
Rear - 11.5 x 20 ET68 - 305/30 ZR 20
Size: Carrera 4/Carrera 4S
Rear - 11.5 x 20 ET48 - 305/30 ZR 20
