Dumb ambient temperature question
Why is it that the temperature readout on my car reads around 21-22 farenheit despite the temperature being much colder? Is an unheated garage somehow warmer than the outside ambient temp?
The other morning is was 5 degrees and it read 22, this am it was 13 and it read 21. This is with the car engine off.
I am assuming the gauge on the car is correct and that somehow the temperature in the garage is higher despite nothing inside generating heat. Not a porsche specific question, but baffling to me.
Any enclosed space, protected from wind, is going to be warmer.
Received 5,413 Likes
Your house is "heating" your garage. As is your hot car parked in the garage.
This happens even with a carport. A little bit of protection from the elements goes a long ways. I've never had to scrape my windshield even when cars on the street are frosted up. Granted I live in Atlanta so it usually doesn't get that much below freezing.
You park a hot 911 in the garage. All that radiant has to go somewhere. There's +6 gallons of hot coolant and anther 2 gallons of hot oil. And a +400 pound block of hot metal.
Well it's a dozen hours later in an Un-insulated garage with the side door open. Overnight temps in single digits. Heat goes up afaik. I suspect that the heat from the cooling engine dissipates out the roof, mainly. No greenhouse effect because it's dark.
Maybe I'll park it in the driveway tonight and see what happens (shudder).
