i know i know, a 4s vs S question
Contrary to the "AWD is for bad weather" sentiment - the 4S is quicker in any weather due to better traction. Sure, if you're Walter Rohrl, you'll be able to drive the S about as fast as the 4S on most tracks, but for real world driving and fun, I think the 4S shines over the S.
BMW does not make any four wheel drive sports cars because of the extra weight (110 lbs for the 4S 911) and the lack of steering purity, due to torque steer among other things. ( I know you will say the BMW 6X is four wheel drive but that's supposed to be a SUV.) You can take it from there.
I went from a C4 to a 2S, I had no idea what I was missing out on in the C4. The C4 will track better, turn better, and is an easier and safer car to drive faster. I enjoyed mine for the 12 years I had it and really appreciated it on those rainy days at the track.
However, the C2 is much more fun to drive. It's fun to push it outside the limits and feel it snap back in (the C4 was so true that it never let me outside the limits). If I had to do it over again, as already suggested, daily driver in poor weather then C4 - no doubts, no questions. But if it's a sunny day weekend type car and your driving is good enough to cut it loose in an open corner then the C2 will give you a bigger grin
I prefer C4, for the safety factor. Even though one may live in a sunny clime, occasionally one drives to areas where the weather may be bad, or turn unexpectedly bad. In addition, we drive at high speeds, its for this reason, I also stay away from cabs.
As an example, one expects great weather in Southern Nevada. Was returning last winter from a trip to death valley and cruising at a pretty good clip, 80 +, when all of a sudden just around the corner there was a 50-100 feet stretch of snow. I can say that the 4 wheel drive helped control the car.
1. I don't know what steering purity means with electrically assisted steering.
2. I have not detected any hint of torque steer and apparently I'm not alone if one can trust the majority of the major reviewers
3. I find the 4s steering to be more precise and responsive than the C2
4. Depending on which set of tests one cares to believe the zero to sixty times and quarter mile times are about the same for both cars so the extra weight doesn't seem to impact straight line performance
5. One could easily take the position that the (slight) extra weight over the front axle improves front to rear balance
The cars do drive differently that's for sure. With our Seattle weather I haven't had an opportunity to "drive" the C4 but I am not expecting to feel any less connected than with the 2s. And I did get a chance to kick out the rear end a couple times.
You will loose some room in the frunk - of that there can be no debate.
Gordon
German magazine Sport Auto did a test between 991 4S and S around Hockemhien in the dry.
4S was the quickest. It's an urban myth that the S is quicker in the dry.
Results were:
Porsche 911 Carrera S vs. 911 Carrera 4S
Both with manual gearboxes.
Dry
- Tyres: Pirelli P Zero
- Weight: 1505 kg vs. 1534 kg
- 0-40 km/h: 1,5 s vs. 1,2 s
- 0-100 km/h: 4,7 s vs. 4,3 s
- 0-160 km/h: 9,9 s vs. 9,4 s
- 0-200 km/h: 15,1 s vs. 14,6 s
- Braking (100-0 km/h): 33,3 m vs. 33,2 m
- Hockenheimring: 1.12,0 min vs. 1.11,7 min
Results were:
Dry
Torque steer? Could you be confusing AWD with FWD? (btw, the next 1-series BMW in Europe will be FWD :-P so much for purity...)
Obviously, this isn't true of all AWD systems - but a well-designed AWD system can absolutely be better, in every conceivable way. I think both Porsche and BMW's AWD systems (no matter how reluctant the latter might be on the part of the manufacturer) definitely fit the bill.
If you want numb, non-driver-oriented AWD, try Audi's latest generation, especially the S6/7. Yuck. Understeer, zero steering feedback, just... ew. And to think it's the same "family" as Porsche.
I took delivery of my 2013 C4S from Danbury CT this past Saturday and dealt with rain through Pennsylvania all the way to Chicago. Heavy rain. All i will say is .....unbelievable! The car is simply incredible. It felt so planted to the road the entire time. I'm not sure how the C2S would have differed, but I can tell you that even in moderate temps, the car drove incredibly well with true road feel.
Torque steer really doesn't apply here as the system in the porsche is HEAVILY biased to the rear. In fact, the 4S starts at 0 drive to the front.
