OEM backup camera - cost installed
#47
Or there is a "camera module" that Porsche installs on the PCM when you build the car with the back up camera?
#49
#51
Come on guys - it's you who's missing the point. if your car wasn't built with the factory camera option you don't have plug and play capability and you will need some type of interface - Nav TV, OEM etc
#54
Platinum Sponsor
Service dept @ my P-d told me that my '15 911 GTS can't be "retro-fitted" with backup camera. So, I asked whether they'll do the labor if i buy OEM parts. The answer was still a No. Then, I read these posts here. And now, I'm scratching my head as to whether the dealer is incompetent, or the service mgr simply didn't like me
#56
here is a picture of the space behind my passenger side tail light - you can see the connectors for the sensors and the camera ...<br/><br/>I believe the white/purple one is the camera (ignore the speech bubble, these are instructions for taking the bumper off
zenman63 (02-13-2020)
#57
Platinum Sponsor
Keep in mind, if you have PCM, Nav-TV makes the interface module that adds a composite camera input to the factory screen. If you have CDR, the radio has to be sent to Nav-TV and modified at a board level to add the inputs.
by the way, if you haven't looked already, the link in my previous post #54 gives a lot of insight on the process.
#58
#59
#60
Platinum Sponsor
