Adding heated sterring wheel
Greetings,
I have a 2013 C4S with the Multi-Function wheel but it is not heated.
Is it possible to swap the wheel for another MF wheel that has heat? Is the proper wiring in the steering console? Or would it also require wiring harness changes?
Dan
2013 C4S
Fort Collins, CO
Dan
2013 C4S
Fort Collins, CO
I'd be interested as well. At minimum I'd guess it would require a new clock spring, control module, and coding. It doesn't seem trivial. Even Suncoast is shying away from this retrofit.
So I have a MF wheel that's not heated and wanted to switch to a heated one, I figured it should be easy? If I can just find a heated wheel?
More importantly can I switch from a 991.1 wheel to a 991.2 wheel????
If you want to upgrade to a heater wheel, you'll need the control module and the heated wheel (the wiring is already in place). The dealer will also have to do some brief coding/programming to activate the heater wheel. It's not very complicated, but the parts from the dealer are very expensive (>$2000).
I have a like new PDK heated multifunction wheel and control board if anyone is interested in upgrading to the heated wheel. PM if you have any questions.
