DVD Audio Not Working
I have tried inserting several DVDs to play the audio track but no luck. I'm selecting DISC in the "Source" menu. It says "Reading Disc" and then nothing. Two pictures:
1. What I see on the MEDIA tab
2. What I see on the MEDIA\OPTION tab. When I try different DVDs, it recognizes the different formats and languages so it is able to read the disc.
What do you see when you put in your DVD?
I do have a US spec car in Europe with Euro maps loaded so not sure if it has defaulted to Region 2 DVDs (Europe) instead of Region 1 (USA), but I can't find anywhere that displays the region. The manual does talk about the ability of the dealer to switch DVD regions up to 5 times. Before taking it in, just wanted to see what others see who listen to the DVD audio tracks.
Thanks and Merry Christmas!
DVD-Audio discs do NOT include Region Coding. Looks as though you're using dvd-video discs which it will not be able to play due to menu structures and etc. DVD-Audio discs come in square shaped jewel cases unlike movies.
Even though it can see the audio tracks on the disc, it has a file structure not compatible for playback.
The playback is great! Thanks for the response "jets."
