Paint correction is worth every penny
#32
So, a couple weekends ago, I went to F1 and the weather was downright atrocious.
I went ahead and dropped her off last tuesday for a full paint correction, 7 Coats of Ceramig Pro 9H, and Xpel front 1/2 wrap. The entire car was coated in Ceramic Pro 9H, wheels in Ceramic Pro Strong, and glass in Ceramic Pro Rain after a full paint correction. Xpel was then applied to full front 1/2 of the car with more layers of Ceramic Pro on top.
I was there too: it was phuckin' awful on Sat - but perhaps the best race of the year on Sun. Even in the Main Grandstand one was pelted by rain at the top level; as the winds made the weather roll in in force.
Appreciate the post re your 911's 'redemption'. I am certainly ascertaining now much additional protection is sufficient. Your car looks terrific!
#33
I gotta be honest, paint "correction" scares me a bit.
If you take ownership of a car with obvious abuse - swirls, spiderwebs etc in the clear coat - I get it.
But I wouldn't take a car out for a "correction" on a whim, or after getting it wet and/or dirty. And I wouldn't do it unless I had a visual reason to do it.
I've seen people "correct" paint simply because it's thicker on one side of the car than the other (as measured with a paint meter.) This is crazy to me! After all, a "correction" is a permanent removal of paint.
It can have dramatic results when it's necessary, no doubt about it. I just hope people realize this is not a weekly detail kind of operation. It's an operation you hopefully do once and only once.
#34
Received 5,407 Likes
I gotta be honest, paint "correction" scares me a bit. If you take ownership of a car with obvious abuse - swirls, spiderwebs etc in the clear coat - I get it. But I wouldn't take a car out for a "correction" on a whim, or after getting it wet and/or dirty. And I wouldn't do it unless I had a visual reason to do it. I've seen people "correct" paint simply because it's thicker on one side of the car than the other (as measured with a paint meter.) This is crazy to me! After all, a "correction" is a permanent removal of paint. It can have dramatic results when it's necessary, no doubt about it. I just hope people realize this is not a weekly detail kind of operation. It's an operation you hopefully do once and only once.
First, on a 991, there is NO removal of paint with a proper paint correction. Only clear coat. We're talking microns here.
Second, our cars can receive a proper paint correction, well within safety parameters, about 25 times. So, for example, a proper paint correction and nano coating like OptiCoat Pro, done every other year (what I have had done in early 2014 and again in late 2015.....2 driving seasons) will allow an owner over 50 years worth of outstanding appearance and coating performance.
#35
Well, removal of clear coat (which is a kind of paint) is what I meant. It gives me the heebie jeebies to sand it off once, much less 25 times. But to each his own!
#36
Your car looks Guards Red. Have you ever seen a Guards Red car with a professional paint correction? It's freaking amazing.
#37
I am a Zaino person and "build up" the clear coat using multiple coats of Z-5. This too looks amazing!
#39
Paint correction will remove the majority of scratches, swirls, holograms, etc. A polish will only remove very light defects.
Here are some before and after pictures of a 'full' paint correction. (compound/heavy polish and a light/finishing polish after) The complete process is very lengthy and time consuming. My average amount of time spent on a car-991 size-is approximately 10-12 hours. I have spent in excess of 20 hours correcting the paint on certain vehicles.
Onto the pics:
![Name: 5050_zpssirqjdgz.jpg
Size: 3.07 MB](https://rennlist.com/forums/attachments/991/1223041d1501482447-paint-correction-is-worth-every-penny-5050_zpssirqjdgz.jpg)
![Name: Before%2014%20swirls_zpsvrt2nlwi.jpg
Size: 3.40 MB](https://rennlist.com/forums/attachments/991/1223042d1501482447-paint-correction-is-worth-every-penny-before-2014-20swirls_zpsvrt2nlwi.jpg)
![Name: Before%2017%20swirls%20galore_zpsd2ulavyz.jpg
Size: 3.60 MB](https://rennlist.com/forums/attachments/991/1223043d1501482447-paint-correction-is-worth-every-penny-before-2017-20swirls-20galore_zpsd2ulavyz.jpg)
![Name: 50501step_zpsf2867907.jpg
Size: 3.18 MB](https://rennlist.com/forums/attachments/991/1223044d1501482447-paint-correction-is-worth-every-penny-50501step_zpsf2867907.jpg)
^^^this is after the first step of 'compounding' or 'heavy polishing'. You can still see a bit of haze left over from the process. There will be some more initial passes and then one to several passes to 'finish' the panel.
After:
![Name: 5_zpsqnwbgjhm.jpg
Size: 3.99 MB](https://rennlist.com/forums/attachments/991/1223045d1501482447-paint-correction-is-worth-every-penny-5_zpsqnwbgjhm.jpg)
![Name: 7_zpshcqruzsp.jpg
Size: 4.05 MB](https://rennlist.com/forums/attachments/991/1223046d1501482447-paint-correction-is-worth-every-penny-7_zpshcqruzsp.jpg)
A Maserati I just did:
Before: you can see the swirl marks here. Paint is dull and almost lifeless. The metallic flake is not popping at all.
![Name: DSCN4695_zpsiyk3zunb.jpg
Size: 4.16 MB](https://rennlist.com/forums/attachments/991/1223047d1501482447-paint-correction-is-worth-every-penny-dscn4695_zpsiyk3zunb.jpg)
Scratches and swirls:
![Name: DSCN4687_zpslokobgk2.jpg
Size: 4.96 MB](https://rennlist.com/forums/attachments/991/1223048d1501482447-paint-correction-is-worth-every-penny-dscn4687_zpslokobgk2.jpg)
Finished with nothing but blue sky and clouds reflecting in the paint!
![Name: DSCN4704_zpscnd5fspd.jpg
Size: 4.44 MB](https://rennlist.com/forums/attachments/991/1223049d1501482447-paint-correction-is-worth-every-penny-dscn4704_zpscnd5fspd.jpg)
To show the results on something other than a dark colored vehicle:
Before
![Name: DSCN4546_zpsmb045kcl.jpg
Size: 3.19 MB](https://rennlist.com/forums/attachments/991/1223050d1501482447-paint-correction-is-worth-every-penny-dscn4546_zpsmb045kcl.jpg)
After-just a nice clear round light reflected from my swirl finder light:
![Name: DSCN4544_zpsqfnxu1yo.jpg
Size: 3.19 MB](https://rennlist.com/forums/attachments/991/1223051d1501482447-paint-correction-is-worth-every-penny-dscn4544_zpsqfnxu1yo.jpg)
Finished vehicle:
![Name: DSCN4562_zpsw8ntcoad.jpg
Size: 5.12 MB](https://rennlist.com/forums/attachments/991/1223052d1501482447-paint-correction-is-worth-every-penny-dscn4562_zpsw8ntcoad.jpg)
A nice 50/50 shot on a red Fiat:
![Name: photo14_zps1bc1f803.jpg
Size: 111.4 KB](https://rennlist.com/forums/attachments/991/1223053d1501482447-paint-correction-is-worth-every-penny-photo14_zps1bc1f803.jpg)
Some 'perfect' paint shots:
![Name: DSCN3823_zpshfrrafte.jpg
Size: 5.39 MB](https://rennlist.com/forums/attachments/991/1223054d1501482447-paint-correction-is-worth-every-penny-dscn3823_zpshfrrafte.jpg)
![Name: yes%202_zpsb0ggec7f.jpg
Size: 4.51 MB](https://rennlist.com/forums/attachments/991/1223055d1501482447-paint-correction-is-worth-every-penny-yes-202_zpsb0ggec7f.jpg)
![Name: 462fe045-0678-4196-8ecd-9787bbeffe8c_zpsk75fpk5c.jpg
Size: 3.92 MB](https://rennlist.com/forums/attachments/991/1223056d1501482447-paint-correction-is-worth-every-penny-462fe045-0678-4196-8ecd-9787bbeffe8c_zpsk75fpk5c.jpg)
![Name: Whatmetallicissupposedtolooklike4_zps0a5ac09e.jpg
Size: 2.44 MB](https://rennlist.com/forums/attachments/991/1223057d1501482447-paint-correction-is-worth-every-penny-whatmetallicissupposedtolooklike4_zps0a5ac09e.jpg)
![Name: Howblackissupposedtolook_zps68be7f6a.jpg
Size: 4.56 MB](https://rennlist.com/forums/attachments/991/1223058d1501482447-paint-correction-is-worth-every-penny-howblackissupposedtolook_zps68be7f6a.jpg)
![Name: getting%20there_zpsepbdbk2t.jpg
Size: 4.88 MB](https://rennlist.com/forums/attachments/991/1223059d1501482447-paint-correction-is-worth-every-penny-getting-20there_zpsepbdbk2t.jpg)
I apologize for the lengthy post! This is a subject near and dear to my heart!
I hope this helps shed some light on the mysteries of paint correction and detailing!
If anyone has any additional questions or would like more info, I am happy to help!
Regards,
Sizzle Chest
#43
I am just trying to shed some light on the subject. It is a mystery to a lot of people. Most think that a basic wash/wax or run through the car wash (!!!!!) is the 'proper' process to 'detail' a vehicle. It is better than doing nothing at all, however, it is a far cry from the correct manner in which to keep your vehicle's finish looking better than new/from the factory!
Again, hope this helps some of our forum people!
