Dealer dropped the entire sway bar, sound went away. Replaced the ends.
This is a pretty nuclear approach fwiw - should be able to disconnect one or both end links and leave the bar installed (but tied up if both ends removed)
hmmm…can you clarify your method please? I will ask my mechanic do it.
I'm finding that my 991.1 exhibits a clunking sound at low speed from the rear. It's almost like a popcorn popping sound. Would the swaybar bushings be a likely culprit?
highly likely the bushings on the drop links... although you might also want to lubricate the bushings in the swaybar mounts themselves ... with the appropriate (silicon) lubricant
Thank you! I'm replacing my variocam solenoids soon so I'll lubricate the mounts when I'm under there.
Does this one seem normal?
(PDCC droplink)
I asked 3 mechanics, they said it’s normal. But it seems not normal for me. If it was a normal drop link, it barely move at the joint here right?
Ps. I am still finding the cause of my clunking noise😣.
