I just fixed that rattle plus some buzzing from the rear side window. Seems to be a common source of noise.
I would like to see or hear about your solution to the rear window noise---I have a noise that I cannot quite track down---lol love these cars but wish the would RD the noise rattles a bit before releasing to the public---
I used this DIY as a guide to remove the B-pillar and then the two bolts that hold the rear side window in place. http://plenums.blogspot.com/2015/03/...de-window.html
Once you remove the two bolts, push the window out from the inside. It won't come out completely since we're not removing the outside trim on top of the glass. Then you can add some felt tape in between the glass and the body. That will tighten the window up and stop the vibrations. https://rennlist.com/forums/991/7785...w-rattles.html
