Reserve your 991 DSC module
#151
I recommend you get a right angled USB cable and leave it connected, you might want to use the modified map that Tom & Mike very kindly tuned for
me when I complained to them that I didn't like the normal setting...
#152
On the USB cable does it have to be right angled? I have a normal USB cable, will it not fit? Plan to see how it is first before I try any modified maps, apparently the coupe is different than the cab so we'll see.
#153
maybe not on the coupe - its kinda a must on the hairdressers car
#154
Basic Sponsor
Larry's help certainly doesn't go unnoticed! He's made my job a lot easier outside of sales as well (I just refer anyone with a Mac to his set of instructions for the tuning software). Larry is certainly one of our most valued customers and will be among the very first I contact next time we're ready for a round of beta testing new products/services.
Thanks for order! Be sure to let us know if there's anything we can assist you with through the install or any custom calibration you wish to do. Look forward to hearing your feedback!
-Jordan
#156
-Jordan
#157
installed my dsc v2 yesterday
very easy plug n play normal mode littl softer now. sport mode has eliminated some bad behavior in fast corners as i have gts 4 pdcc with michelin cup 2. i think that the car with oem ecu
dont understand the plus mechanical grip i give her through aero , tires and more camber. the whole system seems to work very well thoghether now (engine mounts PDCC dampers)
is it normal that pressing the sport or sport + button dont automatic select the stiffer dampers button?
i'm very happy
thank you DSC
i'm very happy
thank you DSC
#158
i'm very happy
thank you DSC
i'm very happy
thank you DSC
#159
Hi everyone, just got my DSC module V2 module thanks to Slim-GT3. Anyone have custom maps they're playing around with or like for sporty street and backroads driving?? The sport plus for me is the closest to what I want but just curious if anyone has had success with custom tunes.
Also, how do you make the software work on a mac?
Great job DSC!!
Great job DSC!!
#160
Great job DSC!!
Great job DSC!!
+1 for new two-mode system - of course the original had 3 maps
#163
there are 3 performance modes, "normal", "sport", and "sport plus" these
primarily effect the ECU (engine and PDK transmission where applicable) and
PSM stability management, *but* there are only two PASM modes, "normal" and "sport".
Not clear if the performance mode (apart from switching PASM from normal to sport) has incremental impact on PASM response within a
particular mode (although it does to PSM) probably only Tom or Mike from TPC could comment on that since it is a function of the interaction
between the ECU (PSM) and the PASM controller (if such exists)
