991 PDK / GT3 PDK
Walk me through that logic. If I'm in regular mode and not manual and im accelerating I pull down and what? Nothing happens because pulling down doesn't do anything. Pushing up puts it in neutral. Right?
Of course. When in D you should not move the lever to change gears. And that is not going to change when the shift/upshift direction reverses in the 991.2.
I think his point is that with the new manual shift directions, if you are accelerating with the shifter in D and you accidentally pull the shifter back to upshift, the transmission will not go to N.
On the other hand, if you are cruising along and step on the gas to accelerate and try to push the shifter forward to downshift, it will go to N.
Wouldn't most people use manual and the paddles anyway?
My Grand Cherokee has an interesting system. The stick does not have a manual position. You just pull the upshift paddle once to put it in the manual mode. To go back to automatic you pull the upshift paddle for about a second or second and a half.
This doesn't make sense. The lever and paddles both shift. My point is that sometimes I forget I am in d and pushing forward on a manual shift puts me in neutral whereas it wouldn't do that if it were the right direction. Doesnt matter what I should or should not be doing.
IF the shift lever is in D: When you push forward you hit N, in both the current 991.1 or the coming 991.2 - no difference.
IF the shift lever is in M (pulled left): When you push forward you upshift in a 991.1 and you will downshift in a 991.2
As far as I know there is no N position in M mode actuated by the shifter. To shift to N with the lever you need to push the shifter right to D and up to N. In some cars you can temporarily reach N pulling back both paddles simultaneously.
These are all the possible lever shifting positions.
Sorry! I am lost. Perhaps we do not understand what you mean.
so confused. but heres my response. there are two modes to be in, manual and automatic. in manual, you are over to the left, up is upshift, down is downshift. so from a stand still you are going to be pressing "up" to upshift.
if, as has happened before, you forget that you are not in manual mode (ie have not shifted the stick over to the left) and you are accelerating, when pushing "up" on the stick you throw the car into neutral. if the 997.2 has the opposite directions (aka, the "right" way), if you were to pull down (again in error) while in automatic mode, nothing would happen
see what i'm saying?
If you are in D and but think you are in M and move the shifter, well...
That's what I have been saying all along. When I am in D but think I'm in M. Sheesh you must really hit it off with the ladies
I'm glad that I'm going to be getting my 911 after they changed the shift directions. Coming from an E46 M3 with SMG II, I would be seriously messed up for a while as the directions would be opposite!
I tend to use the stick more than the paddles when driving, anyone else?
I can only imagine how frustrating it would be. I assume there's been some missed shifts or a pause to think before you shift.
I haven't driven a DCT yet so there'll be a bit of unlearning to do coming from SMG II which is single clutch. There's a lot of throttle work that needs to happen for the E46 M to be driven smoothly. I might end up missing the rawness of the single clutch, who knows? On the other hand I'm quite excited about faster shifts and smoother driving.
