PDCC Bottle Replacement and AWD Controller Oil Maintenance
Is anyone at the 60,000 mile mark yet?
Looking into future maintenance info for the PDCC bottle replacement and AWD Controller oil change.
I know I won't change that PDCC bottle out again.
It's a PITA to get to and when the tech removed the bottle, the tool they used messed up the hard tubing so it needed to be replaced.
It had to come from the mother land so it took a few days to get my car back.
I'll only screw around with the PDCC system again if it starts to leak.
I think the PDCC fluid is just power steering fluid.
I have a 14' TTS - just shy of 60k mi. and a couple of weeks ago, while changing the plugs & coils and the drive belt, I checked the pump and reservoir. Besides clamping down the correct hoses and being careful of liquids, it doesn't look like an impossible job to pull the pump and change out the bottle. I didn't do it since it is not leaking nor am I having problems with it, but for $140 (the cost of the reservoir) it isn't bad preventive maintenance.
Did anyone figure out a part number for the AWD controller fluid? Ive found the part numbers for the 997 C4S and the 991 Turbo (they are different), but Im not sure which one the 991 C4S uses.
