Requesting coolant information
Old Aug 11, 2015 | 04:52 PM
john45in's Avatar
john45in
Default Requesting coolant information
Where's the info. on the coolant? No info. on capacity, when to change, etc. The only thing in the manual is checking the level which I've done (took 28 oz. of mix to bring near max on a 13 C4 and no warnings). My main concern is replacement time and I don't believe in "lifetime".
Old Aug 11, 2015 | 05:02 PM
LexVan's Avatar
LexVan
I just checked the maintenance schedule. It's not mentioned there either. I'll probably have mine changed at around the 5 year mark (50-60,000 miles). Capacity should be at least 6 gallons.
So, how do you check the level? I've never opened that blue trimmed cap yet.
Old Aug 11, 2015 | 08:18 PM
john45in's Avatar
john45in
The little red bobber was at the 'minimum" end (toward the car front); made up a 50-50 mix of Porsche antifreeze/distilled water and added 8 oz. at a time. The bobber began moving toward the "maximum" end and was close to maximum after 24 oz. added. Got the car when 16 months old and added the fluid 2 months later. By the way LexVan, I'm doing my first oil change this weekend going to Mobil 1 5w-50.
Old Aug 11, 2015 | 08:20 PM
LexVan's Avatar
LexVan
Great oil choice. You will be well served.
I'll check my coolant one day soon. I assume cold?
Thanks!
Old Aug 11, 2015 | 08:22 PM
john45in's Avatar
john45in
Yeah, for sure cold.
Old Aug 11, 2015 | 09:59 PM
rnl's Avatar
rnl
Coolant change requires a Porsche programmed computer to cycle and bleed the system. It takes a few hours and don't try it at home. Had it done at 45000 miles
Old Aug 11, 2015 | 10:26 PM
LexVan's Avatar
LexVan
4 hour$? How mu$h wa$ that $ervice?
Old Aug 11, 2015 | 10:58 PM
rnl's Avatar
rnl
$200 Including coolant. They didn't work on it the entire time. Start bleed off cool start bleed ...
Old Aug 11, 2015 | 11:17 PM
LexVan's Avatar
LexVan
Well that was easy. Thanks for this post, John.
Mine needed about 12 ounces of distilled water to get the red bobber in the middle.
A little hard to see with the cabriolet top style engine bay. But my cell phone flashlight saved me.
That cap is wonderful. Works soooooo much better than the old style. Easy off. Easy on. And a "click" to know it's seated and home.
Thanks again.
Old Aug 12, 2015 | 12:30 AM
hansw's Avatar
hansw
After the dealer replaced and refilled the coolant, the system wasn't perfectly bled by their fancy computer-controlled system. Over several drives I had to add a little coolant, each time from about the half mark to the full one. Easy to do, but Porsche shouldn't claim their system reliably fills the coolant system.
Old Aug 12, 2015 | 01:49 AM
Bishop200's Avatar
Bishop200
I asked about this the other day and was told "10 years", which is ridiculous. I will have it done a lot sooner than that!
Old Aug 12, 2015 | 07:14 AM
john45in's Avatar
john45in
Thanks for the information rnl. A change at 4 years seems reasonable to me.
Old Aug 12, 2015 | 07:30 AM
todd92's Avatar
todd92
4 years/45,000 miles is over-maintaining.
Old Aug 12, 2015 | 07:57 PM
john45in's Avatar
john45in
Todd, how do you know it's "over-maintaining"? Would rather be safe that create potential problems due to under-maintaining but no one seems to know when to replace. Like I said earlier, I don't believe in "lifetime" but where's the standard?
Old Aug 12, 2015 | 08:29 PM
LexVan's Avatar
LexVan
He's a troll, John. Ignore 'em.
Sent from my iPhone using Rennlist
