Paint Issue
New C4S, Black/Black.
Paint run/drip drivers side front fender about 1/3 inch long. It appears to have come from the factory with it.
Wet sanded with 3000 grit and got most of it, but still visible.
Short of a repaint, which dealer offered, what can be done?
After wet sanding with 2500 grit (sometimes called wonder paper, cuz you wonder if it is doing anything). Use a flat top bottle cap as your sanding block. Finish with 3M Finesette II.
I hope the drip was in the urethane, and not the base color coat. Good luck....Chris
