Any cabriolets on Bilstein Damptronics?
I am contemplating putting some Bilstein B16 damptronics onto my GTS cabriolet (primarily to reduce ride height and gain corner balance)
Has anyone on the list put their S on the damptronics? I am particularly concerned about the ride quality, since its not clear what the spring rates
are on the bilsteins vs OEM PASM
any thoughts and experiences welcome!
TIA
- Larry
TIA
- Larry
It's clear that the solutions are:
- PASM sport
- lowering springs (techArt, H&R)
- height adjustable springs (KW)
- coilovers (bilstein damptronics)
Well only if you are happy with them grinding off parts of your pasm shock and you can vary the spring rates just as much (w/o revalving) the damptronics I believe and the KW H.A.S s they all take std 2.25" springs
Are you saying those others are also 2.25"?
I thought they were also progressive springs...which I'd like to avoid.
I have the techart springs on my car, I think if I were to do all over again, I would go with the Elephant Racing solution, as having the flexibility of corner balancing and choices of high quality linear swift springs seems super appealing. I guess if I REALLY wanted to go back to stock, you could source new dampers to replace the ones your cut, which wouldn't be a ridiculous amount of money.
The damptronic Bilstein coilover also uses a progressive spring.
I *believe* that both the KW H.A.S and Damptronics are 2.25" linear springs (and helpers) but this assertion is only based on photos of the kits themselves.
