Does anyone have a solution for front license plate for a GTS?
#46
Sorry to hear about the tickets but looks like you found one of the best solutions out there. Out of curiosity, did you get the tickets while parked or were you stopped by police for the missing plate?
#47
Stopped all 3 times. In Ontario you can't get a front plate ticket (or more correctly 'fail to display two plates') if you're not in the car.
#48
Check with your DMV if you haven't. In my state 2 plates are required, but if you run special interest plate you only need one plate on the back. Maybe your state has something similar.
That is what I did and you can get it in vanity as well. It cost 50 per year. The only stipulation here is that it cant be used as a work car, and has to a collector or has to meet other easy criteria.
Maybe you have checked, but just in case!
#49
Got my third front plate ticket (since July) this morning and it looks like I need to do something about it... I went 6 months with the car before getting my first ticket and now it is all downhill. I'm not planning to drill so going to give one of the tow hook options a shot. Issues is I have the parking sensors so wanted something that I could mount low or to the left.
Ended up ordering the rho-plate this morning with the extender bracket below. Looks like it should give me enough flexibility to keep the plate out of the way of the sensor... looks ok too, not optimal of course but I'm committed to not drilling. Should be easy enough to take off/put on too, we'll see.
#51
Here is one quick pic, will try and get some more in the daylight tomorrow. I think I'm going to hit the screws with some black paint and maybe get a rubber grommet for the center to make it disappear a bit more. So far so good.
#53
Well, I got pulled over today at the entrance to the midtown tunnel for no front plate. The cop was very courteous and let me go with a warning when I presented a PBA card along with my license and registration. He did say that he would give me the balance of the week to get the front plate mounted, but that if he sees me next week without a front plate he'll start writing tickets, PBA card and all. The problem I have is that I take the midtown tunnel every day and I'm basically a sitting duck because there are always many cops stationed near the entrance to the tunnel, and there's always bumper to bumper traffic on the way in so the cops will have a pretty good view of the cars driving past. And the 911 isn't an inconspicuous car . . .
I am considering running a US Millworks tow hook mount as I do think it looks better than drilling the factory bracket into the bumper. I guess I would either push the button disabling the parking sensors or will ask the dealer techs if there is a way to disconnect the fuse to just the front sensors but leave the rear sensors operational. I never really understood the use for a front sensor anyway as sight lines out of the front of the car are excellent.
#55
Patrolmen's Benevolent Association. You can get a card if you have a contact in the NYPD. If you get stopped and present a PBA card to the officer, you will "usually" get away with just a warning. Not foolproof but usually works.
#56
I posted this previously on the 991 Turbo Section but maybe it will inspire you guys over here.
I live where not having a front plate is a moving violation with an escalating fine for repeat citations. However I dislike having a front plate on my 991TTS. So I asked my detail and electronics shop to make mine attach via magnets hidden behind the front bumper. Then I can drive with it on when I need to or bring it for a State vehicle inspection which requires both plates on the car.
When I want to remove it at an event, I just lift it off. The only way I can show it to you is on this video they made of of my ALP and STiR Plus custom install.
Look at 00:48 on this video: https://drive.google.com/file/d/0B_t...N0E/view?pli=1
#58
Better pic of mine mounted... as mentioned it does not set off the front parking sensor which was my goal. Looks ok but will be better once I black out the screws.
And also get a new plate as mine is starting to bubble/peel...
#60
In terms of removal, the plate removes from the tow hook bolt fairly easily... just one hex bolt in the middle removes the plate assembly. That would however leave the tow hook bolt in there requiring a 3/4" ratchet/wrench to remove. It is not a tool-less design like the Rennline mount unfortunately... but the plus side is it does not block the front parking sensor either. No best of both worlds available just yet it seems.
Come to think of it not sure the Rennline would spin off on a car with Sport Design/Aerokit lip... not positive but looking down it would appear any attempt to spin the plate off would hit the lip.
