Third day with the Porsche and I already have to take it in the shop?!?!
What. The. Hell?
I was just driving on the freeway, nothing aggressive, and this fault pops up. Anyone have a clue what this could mean? Low on coolant? What's the normal operating temp for a Carrera S?
![](http://i82.photobucket.com/albums/j274/marv800/47fd52fd-0882-4aa2-93b0-c3b83d7b7b8c.jpg)
Received 5,401 Likes
Relax. That's why you have a warranty. Your coolant temp is normal. Check your coolant cap to make sure tight.
Sent from my iPhone using Rennlist
Coolant temp per gauge tops out at 194 with normal street driving.
What year is your car? I think some owners of 991 have had issues with changeover valves failing. For some strange reason, I think you get the message you got when one of the valves fails, just not sure which one. Porsche apparently had a bad batch of those valves.
Not absolutely certain, but pretty sure that is the error message some of them got. Read post #10 in thread below.
https://rennlist.com/forums/991/8002...-on-991-a.html
MY 2014 C2S just had this problem. First repair attempt was replacing a heater valve and with harness which i think there is a tech bulletin about and on the way home light came back on. The car went back again and they found a vacuum line boot leaking. The part is on backorder but they put a "band-aid" and fixed the vacuum leak. Good news is for me it never affecting any performance issues or any type of overheat situation. Hope this helps and maybe settles the nerves a bit. Still waiting for the new replacement line to come in but so far no coolant fault light back on.
What year is your car? I think some owners of 991 have had issues with changeover valves failing. For some strange reason, I think you get the message you got when one of the valves fails, just not sure which one. Porsche apparently had a bad batch of those valves. Not absolutely certain, but pretty sure that is the error message some of them got. Read post #10 in thread below. https://rennlist.com/forums/991/8002...-on-991-a.html
When I got that error message my heat stopped working.
If your heat doesn't work anymore let them know and it will cut down on diagnosis time tremendously. They will know which valve to go after.
Make sure you get a cool loner car.
The good news: most likely a simple fix by replacing a failed changeover valve.
The bad news: Porsche could care less that many owners continue to suffer these failures due to sub-standard parts.
Not a huge deal while the car is under warranty, but how about after?
Another example of electro-technical insanity. A mechanical temp gauge...and the ability to inspect your own coolant level...that is all any car needs. All these idiot lights and the sensors that go with them add nothing to the reliability of the car...they only create confusion and more reasons to flat bed the car back to the dealer.
This is the kindest description I have seen of the issue. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
A campaign to change all valves early on to generation two valves. Now on the fourth generation of valves. (Unless anyone has seen a newer version than the one with model number ending in "F"?)
But to OP, I had a valve go bad, w/ no error message. I also had a vacuum hose to a valve randomly pop off, which resulted in that exact message.
But I did have a horn fail on each of my 997's. Unbelievable. I never had a horn fail on any car I have owned, regardless of price, except ALL three of my 997's. Then of course, there was the faulty clutch ignition lockout switch that failed in mass numbers.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Manufacturers go along because they make the cars more expensive, there's more profits all around. Consumers go along because... sorry gotta go, Kim Kardashian on twitter….
over/under medicated again
