Changed order to GTS
They are a half-inch narrower, but they also receive 5mm spacers (1/5") and then the tires are still the same 305s. I haven't seen one with 5-lugs sitting next to one with CLs to see if the eye can detect any differences in stance from these small differences, but it's possible. But I doubt you can, since the tires are still 305s out back.
But the complaints my GT3 friends have is that even good tire shops often don't understand how easy it is to screw the hubs up with the wrong amount of torque in either direction, and how narrow the allowable range is.
Unless you track and change wheels and brakes several times a year, center locks are not an issue. Changing a CL wheel is not a big deal if you have the right tools and some mechanical dexterity. Most people who fear CL probably would never change their 5 lug either.
Not only do you need a breaker bar and torque wrench good for ~600nm (and calibrated properly), you also need to apply grease to the proper locations each change, as well as following the instructions meticulously which I doubt many non Porsche shops will know. You also can't torque/break the bolts while the car's weight is on the wheel so it must be in the air which then requires someone to be standing on the brakes (2 man job, or get a reverse clamp). Also, once its torqued down, you need to break it free, then torque it again. All of this adds up to quite a hassle when you compare it to the 5 lug system and I don't really see what advantage you get with the CL besides aesthetics.
Lastly, every rotor change requires a new rotor assembly hardware kit (basically 5 nipples where the 5 lug points would normally be) which increases the cost of a brake job. There's also pages and pages of posts regarding CL failure on track as well as a heightened maintenance schedule for the wheel bearings and hubs for cars with CL that see track time. Given all of this, I don't see any positives to the street CL system so if it were my choice on a new GTS, I'd spec the trusty old 5 lug system. The cup car CL system, however, is a whole different story, which sadly doesn't share anything with the street CL system.
