A/C setting question
Hey there, maybe I'm just not doing it correctly, but how do you get your 991 to keep the settings for the A/C? In my Cayenne, whatever temp and fan settings I left on the car when I turn it off will stay the same when I return to the start the car again. However, in the 991, no matter what I leave as the last A/C settings, it always reverts to 72 and auto. Can this be changed? TIA for any input.
Check to see if your Auto Memory function is set to "On" in your multifunction display. I think it is in Vehicle, Settings, Locking. I personally don't like to have it turned on because if it is "On", then every time you lock your car, certain settings are stored on your key and it tends to get things screwed up, at least for me.
This can get frustrating.
I was randomly grabbing a key to use and my setting would just get screwed up.
