Garage door opening using overhead console
#33
I just followed the procedure in the owners manual. Worked fine for me.
#34
Silly question, every time I press the handset during the pairing process, the garage door moves up/down. What do you gents do-switch the operator off the electricity power during pairing? (mine doesn't have infra-red sensor that prevents it from moving)
Also, I don't have a "learn" button on my Hormann operator.
#35
Thanks guys for the responses..I followed the rolling instructions and it finally worked, but I think NoahFect hit it right on the nail! You have HOLD the home link button down to get it working for my Lift master at least, and walaa, Open Sesame!! So for those unable to get it to work, try holding the button down it may be programmed correctly already.
#36
I'm glad that the OP finally got it working. But I have thoughts:
I have heard of other people who have had difficulty with Hormann.
Step 5 is correct, but the first part is technically wrong (although it did work for you). You should point the remote at the front of the car, specifically the center of the bumper. That's where the receiver and transmitter live on Porsches. Every other car, you point it at the HL button.
You should have the sensor, it's a safety thing to avoid crushing the childrens. When it's learning, it shouldn't operate the door. Of course, your unit doesn't have a learn button either... so I think it's a moot point.
#38
#39
#41
Woo! hoo! I celebrated six months of having my new C2S by finally getting it to open my Genie Intellicode garage door opener. I had aimed my remote at the passenger side headlight when I first got my car and got the proper blinks . . . but door would not open with the button in the car.
After printing out all your tips and leaving it sitting on my desk for six months, I finally got out a ladder and took the cover off my opener and pressed the learn button. Jumped down and hopped into the car and pressed the 1 button and it started flashing. Didn't work the first time I pushed it . . . but worked to open it when tried a second time and closed the door when I pushed it again. No more fishing for the remote.
#42
Woo! hoo! I celebrated six months of having my new C2S by finally getting it to open my Genie Intellicode garage door opener. I had aimed my remote at the passenger side headlight when I first got my car and got the proper blinks . . . but door would not open with the button in the car. After printing out all your tips and leaving it sitting on my desk for six months, I finally got out a ladder and took the cover off my opener and pressed the learn button. Jumped down and hopped into the car and pressed the 1 button and it started flashing. Didn't work the first time I pushed it . . . but worked to open it when tried a second time and closed the door when I pushed it again. No more fishing for the remote.
#44
If you have a garage door opener that is an Intellicode I unit (many pre-2012 units), and you have a "universal remote" (perhaps a replacement remote), you are never going to get this to work.
Intellicode I units use 315 MHz, while Intellicode II units can use either/both 315 MHz and 390 MHz. Newer remotes "hunt" between 315 and 390 and it seems that Porsche's in-car system prefers the 390 MHz band, so it will grab the remote's info on the wrong band.
You need a single-frequency 315 MHz remote to program the car. I purchased a Genie Gitr-3 remote on Amazon for $18. On that remote, there is a button with one raised dot that transmits ONLY a 315 MHz Intellicode I signal.
I used that to program the car (per instructions, stand in front, press the button - ONLY the one-dot button). Once programmed (the lights flashed), the car immediately connected to the opener and works with no problems. Note that you do not need to connect the new remote to the opener - the remote is only needed to "teach" the car the correct frequency and pattern.
#45
Here is what I did for my 2015 GTS
(11 years old rolling code garage opener)
1. key on to position 2
2. press 1 until flashing
3. point remote to the front bumper until both signal flashes 3 times
4. press "learn" on the opener in the ceiling of garage
5. press 1 for 2-3 seconds, release if nothing happens, press again for 2-3 seconds until garage door moves (maybe several times until the door moves, make sure no kid or pet under the door).
6. done
Side note -
after completed, my MB E350 did not work so had to redo for MB.
6. done
Side note -
