Emergency Triangle Mount
Old 12-11-2014 | 08:06 PM
Wolfcbr2014's Avatar
Wolfcbr2014
Default Emergency Triangle Mount
Can anyone send me pictures or instructions on how to mount the plastic holders for the emergency triangle in the frunk for a 991 4s. I have the plastic mounts but there were no instructions and it appears you have to cut 2 slots in the carpet to mount it.
Old 12-12-2014 | 01:22 AM
BradB's Avatar
BradB
Pull off and remove the rubber trunk seal above the rear wall of the trunk. Pull the trunk fiberboard liner toward the front of the car and if you look on the back side of the liner you will see markings to guide you where the fiberboard can be trimmed away with an X-Acto knife. This will expose the mounting studs which your clips attach to. Sorry I don't have pics. It's all a tight fit but you can get it done in an hour or less.
Quick Reply: Emergency Triangle Mount
