Thoughts on the aerokit 'ducktail' for the GTS?
#46
So it saves around 10 lbs, which is something but not enough to be noticed from the driver's seat. As stated in a number of posts, it comes down to aesthetics. I need to take a closer look at both in person to make a decision on my build. Thanks for all the information.
I have not seen any figures for this, but I have to imagine that the ducktail is as least efficient than the std spoiler raised, however I suspect that the ducktail may offer additional benefits in this regard
#48
#50
There is the unanswered question regarding the relative efficiency of the ducktail vs the "popup" spoilers in terms of downforce/lift reduction...
The pop-up & duck were the most aerodynamically efficient in their opinion, with the caveat that the pop-up weighed more because of the mechanicals required to raise. Aerokit they weren't as smitten with. Felt there was an drag factor and would hamper performance some. In closing they felt they all looked good!
#52
Ducktail all the way! Don't see it all too often on 991s, but I personally love the look and think it would really set off the appearance of a GTS coupe even more. Here's a quick shot I grabbed of the ducktail on a 1-of-50 (in the U.S.) C2S Sport Design Edition coupe at the local dealer...So sharp!
#55
Newbies Hospitality Director
#56
It should be easy to do that. On a GTS, I am not sure it the wiring would be there to illuminate it as on a 4 GTS.
My only other concern for getting the light strip to replace the black strip would be.... will others think you are a poseur by trying to make your GTS look like a 4 GTS. However, I am sure no one here would mention it.
#57
When you add this... Replacing the original... Do you have to buy a new brake light or does the one in the rear get retrofitted into the tail?
Also... Did you order the tail from Porsche direct (curious as it's shown unpainted)...
#58
All Porsche OEM factory exterior replacement parts come unpainted and in primer only.
Need a new bumper, door, hood, ducktail, etc.? You have to get them painted at your local body shop. Hopefully a very good one that can match the rest of your car very well.
#60
Do it! I saw a duck tail on a cab at the Porsche World Roadshow at Thunderhill in November and loved it!
