3rd Brake Light Modulator
http://www.kahtec.com/smart_stop.htm
Seems easy enough, but have not really looked at the wires to the 3rd brake light. The rubber housing is pretty thick. For those who have installed it, any tips? Does installing it also modulate the brake light in the spoiler?
It really is quite simple to install. You will have to tap into and cut some wires in the 991 harness, but it is very easy to reverse if you need to. Also, I would recommend soldering all connections rather than using the clamp-on taps provided with the Kahtec module. Also, as mentioned in my post on another board, if you don't have one of the fixed-wing aero options you would need 2 modules to have both third brake lights blinking when active.
Stay tuned for more!
