How often do you replace you TPMS?
Old Sep 12, 2014 | 09:41 AM
wanderfalke's Avatar
wanderfalke
Default How often do you replace you TPMS?
Time for new tires @ 16000 miles . I was thinking of replacing one of the sending units on a slowly leaking tire. If it is leaking does the warranty cover the replacement? Dealer quoted 200 dollars a corner so if I replaced all of them it adds 800 dollars every tire replacement cycle. Judging from some of my other dealer quotes I bet you guys are paying 150 or less.
Old Sep 12, 2014 | 09:53 AM
LexVan's Avatar
LexVan
16,000 miles is really good. IMO. For tires. Not TPMS.
Old Sep 12, 2014 | 09:59 AM
2lflat4's Avatar
2lflat4
I'm not sure about the warranty. There is a TPMS rebuild kit that replaces the seals and "guts" of the valve stem.
Old Sep 12, 2014 | 10:01 AM
Jim M.'s Avatar
Jim M.
When I had my Michelin SS put on at Costco I believe I paid $18.00 per wheel. A call to Costco will clear it up.
Old Sep 12, 2014 | 10:17 AM
CSK 911 C4S's Avatar
CSK 911 C4S
The TPMS should really never be replaced unless it's bad. Batteries and seals on the other hand can be replaced. If you drive your car on salt covered roads .... the salt really does a number on the valve stems so you might need to rebuild them sooner then someone in the south. I only rebuilt one set of TMPS on my past Audi and that was after 4 years of ownership (4 sets of tires).
I would get the one checked/replaced that's leaking by but the others should be good for a few more years. Most owners on here won't have their cars long enough to worry about even the batteries going dead in the sensors.
Old Sep 12, 2014 | 10:54 AM
Mark1996's Avatar
Mark1996
I do not see why the new car warranty would not cover the TPMS units if they are faulty. However, it sounds like you are choosing to replace them as preventative maintenance in which case there would be no warranty coverage.
Based on my past experience, you should be able to get at least 3 or 4 years out of the TPMS units.
mtbscott's Avatar
mtbscott
I have never had to change a battery yet or rebuild a TPMS unit in any of the cars I've had with them yet. (As #5 mentions, the longest I had any recent car with them was around 3 years)
The big tire stores like Discount Tire will try to upsell you rebuilds on every tire change, a polite no thank you to that, it's just not necessary. Replace/fix them when they break, not before.
Old Sep 12, 2014 | 01:57 PM
drmatara's Avatar
drmatara
yeah they last about 4-5 years (battery)
Old Sep 12, 2014 | 02:50 PM
kosmo's Avatar
kosmo
first of all the defective TPMS sensors are covered under the basic warranty.
They can last upwards of 7-8 yrs!
a sensor went bad after just 2yrs and the dealer covered it.
GL
Old Sep 12, 2014 | 03:45 PM
BradB's Avatar
BradB
I got 6 years life on my Cayman S.
Old Sep 12, 2014 | 04:44 PM
wanderfalke
Thanks everyone who responded. Interesting that my service advisor tried to sell me one that should be covered under warranty.
Old Sep 13, 2014 | 11:18 AM
lunarx's Avatar
lunarx
I like to change the valve stems with each tire change.
They are only $20 each for the kit.
Since they build up brake dust residue, I like keeping a clean look on the wheels.
(You can get black ones if you have black wheels.)
If you have a TPMS, leak valve stems would fix it.
No need to change sensors, unless they are reading bad, and they would be warranty, in that case.
Old Oct 9, 2016 | 06:12 PM
Jnosol's Avatar
Jnosol
Just to confirm, if I move my TPMS to a new set of wheels I only need the replacement valve stems?
https://www.suncoastparts.com/product/TPMSSTEM.html
Old Oct 10, 2016 | 01:14 AM
TimboCarrera's Avatar
TimboCarrera
Eight years on tha wifes tpms, boxster. If it ain't broke...
Old Oct 10, 2016 | 09:47 AM
DaveGee's Avatar
DaveGee
My understanding and experience is that 5 or 6 years before the batteries in the TPMS start to give up is typical. Like everything, there's always expeditions, but if you're in the "window" and replacing tires anyway, put new sensors in. The price is only about $160 for Huf Intellisens sensors from Pelican Parts. And that includes new stems.
The alternate is to wait for the TPMS to go bad and then pay $160 plus the price to install the sensors and rebalance your wheels. Consider it preventive maintenance.
DaveGee
