Tire replacement stress
#62
That's sad you feel that way. I hope you will change your mind. This forum should be a positive place to be. I dont actually see that anyone on this thread has been remotely offensive to you personally.
#63
Received 5,413 Likes
On the 993 for example. You use the spare only on the front wheel. If you have a flat rear tire, you move the front tire to the rear, and the put the spare on. Drive 50 mph for hundreds of miles.
#65
lets face it there are only a few choices (or not):
1) runflats
2) emergency wheel
- neither of the above are an option...
3) self repair kit (either patch-it-yourself, or the gunk inflator)
4) call roadside assistance
that seems to be the gamut
1) runflats
2) emergency wheel
#67
Unfortunately, there is no easy answer. The solution, according to Porsche, is to use the slime. Plugging the tire on the side of the road is another solution, but you need a jack (buy your own) and finding the hole at night, or even in daylight, could prove difficult. It is hard enough for a guy to do it, and for a woman, even tougher. The last alternative is to call roadside assistance, and wait, wait, wait. I had to wait 3 hours, when my alternator failed, in New York. In the boondocks, who knows how long it would take to get someone there.
#68
Would fix-a-flat be better/worse/same as the factory slime? I've used it before on other cars and it's served its purpose very well but I've never tried it in a large low profile tire like the 991 has.
As for the pressure monitor, how much is it to clean the slime out and replace it?
#69
Who talks like this? You sound like a weirdo. Are you a weirdo?
#70
A little pricy for my liking, but it might give you some piece of mind.
http://www.suncoastparts.com/product/991SPARE.html
For my 2005 Boxster I looked around and found a spare tire.
For longer trips I put the spare in the front trunk, with a small jack and breaker bar, plug kit.
Also makes a nice weight to prevent the theft of my mountain bike.
#71
AAA Premier RV costs only $ 105 per year. If the tire is severely damaged, call AAA road service and request a flat bed. They will flatbed your car 200 miles per year 1X and 100 miles per year several times. If the tire can be fixed, request they bring a tank of air, hand the driver your vulcanized tire repair kit, then flip him $ 20. I've never had to wait more than one hour for AAA. T
