PDCC option
Old Jul 24, 2014 | 08:20 PM
  #31
LexVan's Avatar
LexVan
Originally Posted by promocop
OK...now how does DEM (dynamic engine mounts?) work in this scenario? Seems like there is some redundancy here..NO?
If you select the Sport Chrono option, you get in addition dynamic engine mounts. And rev matching with the MT 7 speed.
For example, in the Boxster, you get dynamic transmission mounts, not engine mounts, because of the mid engine setup. Just an FYI.
Old Jul 24, 2014 | 08:23 PM
  #32
promocop's Avatar
promocop
Ive heard about this rev matching deal. Can you turn it off?
Old Jul 24, 2014 | 08:24 PM
  #33
LexVan's Avatar
LexVan
Yes. By turning off PSM. Or by not being in Sport Plus. Simple.
So, you can be in Sport Plus, with PSM off, and disable the rev matching.
Old Jul 24, 2014 | 08:26 PM
  #34
hinckley's Avatar
hinckley
Originally Posted by LexVan
PASM is Porsche Active Suspension Management. It has nothing to do with engine mapping and throttle response.
Sport Chrono controls throttle response and the engagement parameters of PSM (Porsche Stability Management).
These are a couple of the main corrections necessary.
LexVan - I'm glad I posted. That's really helpful and makes me better understand the desirability of Sport Chrono. I'll make corrections to my post. Thanks.
Old Jul 24, 2014 | 08:28 PM
  #35
LexVan's Avatar
LexVan
As a side note, these are electro magnetic. They came over to us from the 997 GT3 technology. Forget if gen 1 or gen 2.
Old Jul 24, 2014 | 08:32 PM
  #36
hinckley's Avatar
hinckley
LexVan, with PASM, if the Sport button is on, but the Damper button is switched off, what is the Sport button doing?
Old Jul 24, 2014 | 08:38 PM
  #37
promocop's Avatar
promocop
and Why is the only way to turn off rev matching activated is to turn off PSM? doesn't make sense
  #38
LexVan's Avatar
LexVan
In this case, you'd have more aggressive throttle mapping, more lenient PSM, if you have PSE it would be on too, and the chassis would be in a more comfort setting, not firm.
Old Jul 24, 2014 | 08:41 PM
  #39
LexVan's Avatar
LexVan
We learned about this a few weeks ago from a sharp Rennlister who did not want rev matching when tracking his car because he wanted to do his own heel toeing. But he wanted to be be in Sport Plus mode for other reasons ( runs cooler, throttle response......).
Old Jul 24, 2014 | 08:43 PM
  #40
promocop's Avatar
promocop
Go that,but if you turn off PSM aren't you giving up some yaw/pitch?
Old Jul 24, 2014 | 08:45 PM
  #41
hinckley's Avatar
hinckley
I'm trying not to get too dizzy - You said that PASM doesn't impact throttle response, but the Sport button does. So are you saying that the Sport button is not really part of PASM? btw, is PASM standard on all models now?
Old Jul 24, 2014 | 08:54 PM
  #42
LexVan's Avatar
LexVan
PSM:
Please
Save
Me!!
Or:
Porsche
Save
Me!!
Not sure I understand your question.
When you turn off PSM you are allowing the car to get very sideways and allow tire spin. Just to name a couple.
In an emergency situation, like a spin, PSM will re-engage but you're probably already toast.
Old Jul 24, 2014 | 08:56 PM
  #43
hinckley's Avatar
hinckley
promocop - PSM and PASM are two entirely different systems.
Not so easy, huh??
  #44
promocop's Avatar
promocop
ok
Old Jul 24, 2014 | 09:00 PM
  #45
promocop's Avatar
promocop
ok...yea thats what meant . why did Porsche tie the blipping function to PSM ? why not a separate on/off without affecting other controls??
