they function like stock? Does the neutral feature work?
Yes - neutral works and they function perfectly. The part that looks like the old “buttons” do nor have functionality or move. Just the paddles. I love it.
I was more interested in just swapping the wheel and not adding the MF stalk.
Hello,
Were you able to do this swap without worrying about the column stalk or throwing codes? I have a multifunction wheel (no heat) and want to purchase the original sport design wheel for 991.1. I'm guessing the stalk is for toggling through the display screen to the right of the tachometer.
If coding is needed, though, so be it, I absolutely want the SD wheel !
