Water in footwell
#47
I'm with this guy. But I finally gave up on finding the 991.1 that I wanted without a sunroof. So, now I am concerned this will happen to me one day.
Recently I opened my sunroof and tried to find the drain inlets so that I could blast them clear with compressed air, but I could not see any way to access them. On my old BMW sunroof car, it was easy to find the drain lines at the 4 corners of the sunroof and clean them out. I learned that lesson the hard way.
Does anyone know how to access the drains on a 991 to clean them out ? - I'm stumped.
Bud Taylor (08-16-2020)
#48
water issue
Dealer called and told me they really really fixed the problem this time. Apparently the drain in the lower part of the car - which can't be accessed or seen or cleaned without removing pieces of the car and something inside the wheel well - was clogged with debris and draining into the rear footwell. They also said it was the first 991 they had seen it happen to; which sounds to me like they had seen it on other models; which begets the question - why didn't they check it the first time I had it in there?!?
Dear Kelly i have a 911.2 Carrera S 2018 and the same issue of water in the passenger well as you have mentioned can you please tell me the final issue what had happened and why water had collected in the passenger base .
my dealership is trying to figure it but cannot since the past 7 days so i thought i will message you and check and it wold help me please
my driver side is completely dry , the roof is dry the car just sat in heavy rain over 3 days and then on the 4th day i realized water filled to the tee
please help and mail me if possible on zainrrais@gmail.com
regards
zain
#49
#50
Be careful using compressed air to clear a plugged drain tube.
Usually the drain tube is a rubber hose of some sort and if it's clogged with debris, shooting compressed in it may disconnect it from the drain nipple. The problem here is that the hose may end up in an unreachable abyss, never to be seen again.
Jason
Jason
#51
please assist me to the solution
HI how did you get on with your leak diagnosis and fix? Ive a 991.2 GTS with really wet footwell similar to you. Dealer has stripped out the passenger side (UK car LHS) seats, carpet right down to bare metal floorpan and cant seem to locate the waters entry point. The drain you mention in the rear wheel well can you tell me more about that. I'm not sure the dealer has checked that as the wheels has not been removed to access the inner wheel arch or anything like that. The dealer is working at it but I'm keen to suggest anything that may help as they may run out of ideas soon. The facts are the water was in teh rear and front foot well, so suggest to me its coming in from the rear as the rear floorpan is higher than the front, easier for water to run down than up. Its only on the LHS of the car. Any drains you can think of? Its a targa GTS.
DEAR JAKOB - WHAT WAS THE FINAL DIAGNOSE I AM IN A SIMILAR SITUATION AND WE TRYING EVERYWHERE TO FIGURE THIS AND THE SERVICE CENTRE JUST CANNOT FIND A SOLUTION TO THIS ISSUE PLEASE ASSIST ME TO WHAT FINAL DECISION THEY TOOK TO STOP THE WATER ENTRY
#52
Read cross post..
Deleted...
Deleted...
#53
regards
zain
regards
zain
I had this problem in a BMW, and once in a Boxster. Both times turned out to be blocked drains from the roof - once from the convertible top and once from the sunroof.
#54
I had that issue myself with a VW. It turned out to be the AC drain hose that is supposed to drain condensation onto the ground was pushed upward into the car and was draining in my passenger side footwell.
The dealer had done it and blamed me. Check for the drain hose.
#55
As common as this issue seems to be - and only happens to passenger side - makes me think it is somehow related to the seal or drain on the Gas tank lid and the opening there ...
Worth checking into it
I just bought a 2019 991.2 C2S - hearing these sort of issues is a bit concerning!
Z
#56
I just spoke with a Porsche service advisor today who informed me that as part of their intermediate and major services on the 991 that they clear out the drains for the AC, sunroof, and body. Unfortunately they did not explain to me the precise steps they take to do so but obviously there is a known method for clearing these drains out. We need to figure this out somehow.
#57
#58
Yeo, been trying to find out where they are for years. One of the grand Porsche mysteries!
#60
So, On Christmas Eve, my windows steamed u when I parked the car after an hour drive following the audio stopped producing sound and the dash display said: "unknown audio source" and I discovered wet REAR carpet on my 991 c2s CAB. I left it alone yesterday whilst I ate, drank and was as merry as I could be knowing there was a problem with my car, but today I pulled out the rear seats which were dry underneath, the front driver's side (remember this is a RHD UK car) and the carpet which the 2-inch thick foam on the underside was soaking wet in the front and rear. It's worth noting that the upper side of the front was dry to the touch despite my feet being on it whilst driving yet the rear footwell was wet to the touch despite nobody having been in there in months. The worst part of it is that the amp which is under the driver's seat was wet. I have taken that out and I checked the passenger side which seems to be dry front and rear. The carpet is now hanging in the garage drying out.
The annoying part is I can't find the source of the water.
Anybody know a UK based place who might be able to repair my flooded amp!?
- I have checked with a hosepipe, both the drains under the clamshell each side of the rubber seal it sits on both side of the car. They were not blocked and there is no evidence of water coming-in directly under the rear seats.
- I haven't yet managed to get access under the metal base of the rear seats where there is more as yet to be identified electronics and which the rear wheels arches back directly onto.
- I have also checked the water is draining off the front screen in the way it is intended which seems OK as well.
- I have also used the hose on various seals on the front firewall without managing to produce a leak.
- The final potential culprit is the A/C drain which in a RHD UK car runs under the carpet from the top of the transmission tunnel down to the base of the floor pan in the driver's tub. It looks OK to me and I disconnected it at the top and blew down it and it was not blocked.
