Water in footwell
#61
Nick M. seems to have had the same issue:
check in @3:45 minutes.
I wonder where the water is coming from? Also if the problems he had with his car are a result from the water? Probably…
I bought my Carrera used and the screws, which hold the passenger seat in place at the bottom are rusted. Can I assume that my Porsche had the "water in foodwell" issue in the past as well?
Are these screws which hold the seat to the sheet metal floor always rusty?
#62
Snap!!!
So, On Christmas Eve, my windows steamed u when I parked the car after an hour drive following the audio stopped producing sound and the dash display said: "unknown audio source" and I discovered wet REAR carpet on my 991 c2s CAB. I left it alone yesterday whilst I ate, drank and was as merry as I could be knowing there was a problem with my car, but today I pulled out the rear seats which were dry underneath, the front driver's side (remember this is a RHD UK car) and the carpet which the 2-inch thick foam on the underside was soaking wet in the front and rear. It's worth noting that the upper side of the front was dry to the touch despite my feet being on it whilst driving yet the rear footwell was wet to the touch despite nobody having been in there in months. The worst part of it is that the amp which is under the driver's seat was wet. I have taken that out and I checked the passenger side which seems to be dry front and rear. The carpet is now hanging in the garage drying out.
The annoying part is I can't find the source of the water.
Anybody know a UK based place who might be able to repair my flooded amp!?
- I have checked with a hosepipe, both the drains under the clamshell each side of the rubber seal it sits on both side of the car. They were not blocked and there is no evidence of water coming-in directly under the rear seats.
- I haven't yet managed to get access under the metal base of the rear seats where there is more as yet to be identified electronics and which the rear wheels arches back directly onto.
- I have also checked the water is draining off the front screen in the way it is intended which seems OK as well.
- I have also used the hose on various seals on the front firewall without managing to produce a leak.
- The final potential culprit is the A/C drain which in a RHD UK car runs under the carpet from the top of the transmission tunnel down to the base of the floor pan in the driver's tub. It looks OK to me and I disconnected it at the top and blew down it and it was not blocked.
dude, I’ve had the EXACT same problem with my 991.1
Driver-side football completely flooded, I’m sitting in about an inch of water
Send it off to a company called boss and Repairs online and they can’t fix it due to too much damage
Took it to a Porsche specialist, they couldn’t find the problem ffs 🤦♂️
So they charge me 200 quid told me they cleared. The drains and lo and behold is flooded again.
I am so annoyed at this stage
Apparently they’ve checked the AC drainage. All the drainage channels are not blocked.
I feel this is the manufacturer fault, and Porsche should be sorting this for us!
Please keep me posted
#63
Just came across this on facebook:
https://www.facebook.com/reel/972412184355274
Sorry can't post it in any other way, since the OP on facebook put his message in a "reel" - why do people do this anyway?
