First track day with the 991 S
Today I ran with Chin Motorsports at Watkins Glen. The weather was perfect, which is a bonus for the Glen. This track seems to have its own weather patterns, which are often less than ideal. Today the skies smiled on us. In no particular order, here is my collection of thoughts on the 991 at the track today:
- This car lives to rocket out of turns from apex to track-out. Really an amazing experience. I always marvelled at how GT3s that I was keeping pace with in the M3 would squirt so easily away from me coming out of turns. Now I get to experience it myself.
- With my GiroDisc rotors, Pagid RS29 pads and Motul fluid, the brakes held up very well on a track notorious for cooking brakes. Very pleased with the braking performance.
- I hate to say it, but the PDK was a bit of a let-down, and at least for now seems inferior to the DCT in the E90 M3. The DCT paddles have more of a positive, direct engagement, while the PDK paddles feel a bit more "electronic," like there is a layer of software interaction between your fingers and the shift action (which, of course, there is, but it's much less obvious in the M3). More important, and more disappointing, the PDK intervenes when it's not wanted. On a couple of occasions I came out of a slower turn (toe of the boot) in a gear higher than ideal because I had caught another, slower car, and didn't want to downshift in the middle of the turn. When I would put the accelerator to the floor to make the pass coming out of the turn, the PDK automatically downshifted on these two occasions from 3rd to 2nd, as a "kickdown" mode. This was while I was running in manual mode. It was not only a surprise, but felt like it could throw the balance of the car off as it suddenly downshifted and jerked the driveline. I was not pleased. Similarly, on one occasion I was approaching a braking zone while close to the rev limiter in a particular gear. I held it for an additional half a second rather than doing a quick upshift-downshift just prior to braking. Rather than bounce off a soft rev limiter or hold the revs, the car automatically upshifted without my intervention. Again, a surprise and a feeling of upsetting the car's balance. I also noticed that under ful-throttle upshifts on a straight, the car tends to lurch forward a bit. While there are no cornering forces on the car at this point, it still feels a bit unsettled for the chassis. I ran my M3's DCT in full manual mode at all times, both track and street, and never had these experiences with it. Is there any option or method for defeating some of these automatic take-over modes with the PDK? I have to believe that the GT3's PDK does not behave this way; otherwise people will be demanding a reprogramming update from Porsche.
- As others have mentioned, the water temp gauge never climbed above 194deg F. So either the thermostat does an amazing job of maintaining an exact, ideal temperature, or the water temp gauge is essentially a "cold" and "warm" gauge with "warm" preset at 194, regardless of the actual temp.
- Oil temps ran as high as 265deg F during 30-min sessions. Ambient temp was 69-72deg F.
- According to the onboard oil level measurement, the car didn't burn any oil during the day.
- Oil pressue, which normally runs around 20-35psi on the street, ran as high as 65psi on the track during high-rpm periods.
- The Yokohama AD08R tires did very well--gripped well, and didn't get greasy or chunk apart. I bled out pressure to keep them around 36psi front and 39-40psi rear.
- Overall, the balance of the car felt very solid and confidence-inspiring. By the end of the day, I had done a lap in this car on street tires two seconds faster than my best time in the M3 on R-comps. And I feel that there is quite a bit left in the car once I get more and more comfortable with it.
Again, it was an overall excellent first track experience with the car. With more time and familiarity with ideal revs/gear selection at various points on different tracks, I can hopefully avoid the PDK going rogue and acting on its own.
As a fun aside, the Tudor Sports Car series was arriving in town today to set up for practice sessions over the next couple of days. (The next race at the Glen is in June.) The transporters were filling up the paddock, and James Clay from Bimmerworld was actually running a beautiful E46 M3 club racer in the advanced group with Chin today. This evening I actually ran into Ryan Dalziel on the hotel elevator after dinner. Pretty cool.
Here's a clip of a lap or two from today. I apololgize for the pathetic video quality from my RaceKeeper system. The bullet cameras are not high-def, and the rollbar location makes the front camera do light metering off the dark interior of the car, with a resultant washout/overexposure of the image outside.
Might be worth giving that a try.
Regarding full throttle upshifts. Same here in my car in SportPlus. Car lurches forward (actually after doing a slight squat in the rear first), unsettling the car, and on less than perfect pavement or a less than perfectly straight road it feels like it will step out in the rear. I had a topic before about that, but people basically told me I had no business driving a sportscar, so I let it go and thought I was being overly sensitive and incapable. Now I'm glad one of the experienced members here has had same experience and I'm not alone ... :-)
The lurching issue is real--you're right. The DCT in my E90 M3 would also give a bit of a kick during full-throttle upshifts on track, but it would never create this forward lurch feeling like the 991's PDK does.
You go to the settings of your car and select 19 inch.
Here's a clip of the SRT Viper, followed by the Falken 991.
And here are a couple of LMP2 cars. The lead car must have been running a V8--sounded incredible.
I wonder how banging in the gears with a sequential racing dogbox would feel on a cup car ...
I'm sure the sequential box feels great, and somehow feels violent yet not upsetting to the car's balance.
I have a MY2014 PDK and in manual and Sports Plus it will rev deep into the red. If I only select Sport and manual then the box changes up on its own as you hit the red. Hope that helps.
Tom
