Just purchased a Uniden R7… 12v connector doesn’t fit well so planning to do the mirror tap. Always a little nervous touching electronics in cars… but will give it a try.
I havent purchased the tap yet but did remove the overhead cover and noted the connector at right is all yellow, not the yellow/blue as in the first post.
Attached is a picture.
Would appreciate if someone can confirm if the all yellow connector is the correct one and if I should tap the right side of it as follows: red to blue and black to brown (not tapping the center wire). Picture from the overhead of 2012 C2S
