21's or 22's...?
Oh, I like stance & all...but was actually looking for a set of 19's so can run some Hoosiers, no 20" sizes.
But almost all the wheel manufactuers are promoting the larger sizes vs. smaller ones.
A 22 with same size diameter would have an inch less sidewall...scary thought there.
It's annoying enough that 20" wheels are standard on the Carrera S, and offered on the even smaller Boxster/Cayman S. I can't imagine that a 20" wheel was a pure engineering/driving dynamics decision on the part of Porsche. They're simply giving in to popular trends for street looks. If 20" wheels were go-fast parts, they'd be on all the Rolex series (sorry, Tudor) and Continental Challenge cars.
21" and 22" wheels would essentially degrade much of the performance that one pays for in getting a 911--slower acceleration, longer braking distances, worse handling...
I find it ironic that my car will have the 20" OEM wheels as its winter setup with winter tires, while the summer/track setup will be 19" wheels...or perhaps not ironic at all.
I think it is in their blood to have form follow function. I don't understand the physics as well as many of you, but i assume the shorter sidewall on 20" wheels must have some positive impact on lateral stability?
If, on the other hand, I maintained the same overall diameter as the stock 20" setup, I'd have to go with 255/40-19 and 295/35-19 tires, which would have increased the sidewall height significantly, probably with a resulting decrease in crispness and responsiveness.
My point, then, is that it is possible to go with a smaller diameter wheel and still keep the same sidewall height, as long as you're willing to reduce the overall wheel/tire diameter somewhat. I've heard it said that a wheel's diameter should only be as large as is necessary to clear the brakes--anything else is just excess weight. To a large extent, this is probably true. This is why I think the Boxster S and Cayman S look so silly with their relatively small brake rotors floating inside massive 20" wheels.
