Advice for 991 options list
Vented seats are one of the best options available. Where you live it sounds like you will "need" them less than most places, but its a great thing to have especially considering its one of the cheapest options you can get (assuming you're going to get heated seats anyway, which are a MUST).
While you can use heated and vented at the same time, you probably won't do that very often if at all. If its cool enough to warrant the heat, the venting will make it too cool. You could then turn up the heat to compensate for it, but I see no point in that. So vented in the winter is pretty useless. But for summer days or anytime you want a little cooling but don't want to run your AC (for fuel efficiency or to preserve HP, etc) it can be of use.
Often overlooked is the heated stearing wheel. Only a couple hundred bucks and it works GREAT. Highly recommend it.
Yes pretty sure it was RSS, box is in the office, snowed in today. you can see I got black ones to match my rims.
Heated/ventilated seats good option, even here in South FL. Heat not so much, vent. used a lot. My 14 C2S has RSS 7 and 14 spacers, Carrera Classic wheels and PASM. No problems and nice stance.
On the ventilated seats the thigh and shoulder bolsters are perforated as well as the center panels. I agree that the non-ventilated seats look much better with non-perforated leather on the bolsters.
Oh, I guess. I just can't see anyone basing the decision on that. If you want vented, even a little bit, who would not get it just because of the lumbar perf?
