Curious About Your Recommended Design Updates?
If you had input to Porsche’s design process what design changes would you recommend for future model years of the 991
I personally am happy with the 991 in its present guise. I'm pretty sure the 991.2 will follow typical Porsche fashion and have small horsepower bumps for all variations, new wheel choices, cosmetic facelifts, and some new options. Never say never but I'm thinking that nothing that could be coming would be enough in itself for me to swap.
Smaller (2 seater) is Cayman or CGT, bigger is rear engine Panny.
Almost all of the wish-list items I have on my 981BS would apply to the 991 as well. Worth mentioning here because a 991.2 will probably be my next car:
- Provide manual frunk release for easier access to battery.
- Offer an optional compact spare tire solution of some kind.
- Reduce amount of force needed to close frunk.
- Provide front/rear cameras, or at least reorient the ultrasonic sensors to allow them to detect low curbs.
- Update nav/sound system to current mobile industry standards.
- Lose the electronic parking brake, or at least make it activate automatically (and deactivate without a clunk/lurch).
- Allow customer to enable/disable hill hold feature on manuals. Doesn't affect me personally but it was one factor that encouraged me to go with PDK.
- Likewise, allow customer to enable/disable rev matching independently of Sport/Sport+ mode selection.
- Don't force customers to choose between Sport Design paddles and MF wheel options.
- Reduce throttle return spring tension, or remove the secondary spring altogether.
- Allow PDK to disable sequential downshifts under braking in Auto mode. This pointless feature is probably my only real complaint about PDK. Suggest enabling it in Sport+ mode only.
- Lower volume of horn when locking doors, refine the sound, and allow customer to enable/disable it without PIWIS.
- Provide single .PDF download for owner's manual.
- Provide .PDF download for service manual. (Also, I want a pony for Christmas)
- Implement one-touch top up/down control for convertible models. Should not require $200 add-on for this.
- Likewise, front grill guards should be standard on all models.
- Preserve settings of ALL console buttons between drive cycles, not just some of them.
- Lose the analog speedometer in favor of more useful gauges. Not an issue for 991 models but would be appreciated in 981.
- First World Problem department: heated steering wheel and seats don't seem to work very consistently. Sometimes the steering wheel heat is almost undetectable, other times it works fine.
- Gear indicator on manual transmission should reflect the gate selection before clutch engagement, not after. Doesn't affect me but it's a real forehead-slapper.
- (981 only) Allow customer to order a black tachometer face on the 'S' model. The silver face is ridiculously hard to read. I assume this isn't a problem on the 991S?
- Currently less than half of the engine's RPM range ends up being needed in normal street driving. I'd probably leave 7th as-is, and spread out the 2-6 ratios a bit more. I don't know if this applies to the 991 or not, but I've seen other people mention it.
Received 5,388 Likes
Get rid of the little hump/bump for satellite radio. Get rid of park assist bumper dimples.
As far as curves and edges in the sheet metal, no complaints there. Most of the things I'd argue for, like lower beltlines, are driven by regulatory compromises rather than artistic ones.
I thought about mentioning that, but it doesn't bother me that much, and the satellite reception is already not the best. If I asked for better reception I'd risk getting a bigger antenna hump. If I asked for a smaller antenna I'd get even worse reception. So it seemed smarter not to complain.
Becuase the others weren't?
(I agree with much of your list).
Pure aesthetics -- I would prefer a slightly different headlight treatment. I know Mr. Mauer wants to emphasize "super car wide" but the headlights are too far apart, pushed out too wide, IMHO.
(I apologize in advance for joining the "they don't make 'em like they used to club, but the 997 had better balanced headlights -- both positioning and the more traditional 911-looking shape (sans the "bulge").
I would prefer a bit more fender flare and the lights a bit closer together. I think this would look more 911 (RSR perhaps, but still) and less 356:
